Questo scommetterei che non lo conosce nemmeno Gianni Zadra. Pare che sia stato commercializzato in serie limitatissima ad un prezzo di listino di 18,000 $.
Che roba!
[attachmentid=36343]
Specifications:
Name:
300mm T2.2 (F2.0). Lens made by Tochigi Nikon
(T display is a numerical value that considers the permeability of the lens element. It becomes F2.0 in a usual F display.)
Size:
maximum diameter = 163mm, Length = 330mm
Weight:
Main body = 7.5 Kg, Two step expansion lens hood = 0.5Kg
Lens composition:
9 group 12 pieces (three ED lens use) and 1 overall protection glass and 2 dummy back filters
The mount:
No mechanical synchronization pin and information point of contact.
Please use it with the 100% manually setting. (No AE or AF)
The filter:
Equipped with two filter folder and slots, which makes it possible to use two 52mm screw in filters at same time.
[attachmentid=36344]
