Uso la conversione in profilo sRGB come ultima operazione del mio workflow.
Oggi ho trovato in dpreview questa semplice descrizione della distinzione tra i due:
http://forums.dpreview.com/forums/read.asp...essage=26487628
For all practical purposes Nikon sRGB 4.0.0.3001 profile is absolutely identical to sRGB IEC61966-2.1 profile; that is colorimetrically the profiles are equal.
For the purpose of encoding data coming out of the NC/NX Nikon's version is slightly better because it contains more precise gamma curve, 4096 points instead of 1024. Thus you have less artefacts in the resulting image.
Sembrerebbe quindi meglio usare il profilo Nikon....
Avete info a riguardo ?
