SOLUZIONE!!!!
If this is a double post, or old news,�Daschund can remove or unstick the thread. It gives me big trouble on my new system.
Nikon Capture 4.x and probably Nikon View 6.x also, will not work on an AMD-64bit system and Windows XP SP2 installed. The computer will crash (blue screen and reboots)
On other systems you can try to disable the 'Data Execution Protection' . It will not work with the above configuration, because the problem is partly caused by AMD�s 64-bit processor.
Links:
Microsoft tackles AMD conflict in SP2 (copy-paste whole part between the hooks):
http://news.com.com/Microsoft+tackles+AMD+...-1016_3-5326707]
Detailed description of the data execution prevention feature in Windows XP SP2
The thumbnail fix with NEF files is easy:
http://forums.dpreview.com/forums/read.asp...essage=10188326All the best,
Hendrik
Update :
This is an temporarily solution (disabling �No Execute� feature). I recommend changing back to the default after Nikon released a working update.
Go to the control panel (classic view) double click �System�.
Choose �Advanced� tab, In the �Startup and Recovery� section click the �settings� button.
Then click �Edit� button in system startup.
This will open Notepad and will open your BOOT.INI file. At the end of the file you will see /NoExecute=OptOut.
Change �OptOut� to �AlwaysOff�. Close Notepad and save (click yes and ok).
After reboot Nikon Capture 4 should work without any problems.
