nippokid (was here)
Le prime immagini pubbliche della Nikon D3x (Jpeg).
� Aleksandar Dunkic. Concert of Emir Kusturica and TNSO, Belgrade Arena, Serbia
2008.11.29
Qui
SkZ
Miiiii, se e' lento quel sito
nippokid (was here)
nippokid (was here)
Camera: Nikon D3X
Exposure: 0.025 sec (1/40)
Aperture: f/2.8
Focal Length: 155 mm
ISO Speed: 1400
Exposure Bias: 0/6 EV
ISO Speed: 1400
Orientation: Horizontal (normal)
X-Resolution: 300 dpi
Y-Resolution: 300 dpi
Software: Ver.0.66
Date and Time: 2008:11:29 19:33:24
YCbCr Positioning: Co-Sited
Exposure Program: Normal
Date and Time (Original): 2008:11:29 19:33:24
Date and Time (Digitized): 2008:11:29 19:33:24
Compressed Bits per Pixel: 2 bits
Maximum Lens Aperture: 30/10
Metering Mode: Pattern
Sub-Second Time: 08
Sub-Second Time (Original): 08
Sub-Second Time (Digitized): 08
Color Space: sRGB
Sensing Method: One-chip colour area sensor
CFA Pattern: RED GREEN GREEN BLUE
Digital Zoom Ratio: 1/1
Focal Length In 35mm Film: 155
Gain Control: High gain up
Compression: JPEG
Quality: NORMAL
White Balance: AUTO
Focus Mode: AF-S
Flash Setting: NORMAL
White Balance Bias Value: 0, 0
White Balance Red, Blue Coefficients: 586/256, 404/256, 256/256, 256/256
Thumbnail IFD Offset: 8102
ISO Speed Requested: 100 (May be different to Speed Used when Auto ISO is on)
Photo corner coordinates: 0, 0, 6048, 4032
AE Bracket Compensation Applied: 0/6
Tag::Nikon Type 3::0x001B: 0, 6080, 4044, 6080, 4044, 0, 0
Tag::Nikon Type 3::0x001D: 5000156
Tag::Nikon Type 3::0x001E: 1
Tag::Nikon Type 3::0x002A: 3
Lens Type: 14
Lens Min/Max Focal Length, Min/Max Aperture: 700/10, 2000/10, 28/10, 28/10
Bracketing & Shooting Mode: Shooting Mode: Continuous AE/Flash Bracketing Off White Balance Bracketing Off
Tag::Nikon Type 3::0x008A: 2
Noise Reduction: OFF
Tag::Nikon Type 3::0x00A2: 6060539
Total Number of Shutter Releases for Camera: 454
Tag::Nikon Type 3::0x00B1: 4
Image Width: 6048 pixels
Image Height: 4032 pixels
vvtyise@tin.it
con la luce del giorno vedremo meglio!
nippokid (was here)
vvtyise@tin.it
tutto ...chiaro!
F.Giuffra
Eccola!
D3x
F.Giuffra
Ma non ho trovato ancora nulla sulla qualit� a 16 bit...
Nital D3x qui
alcarbo
QUOTE(F.Giuffra @ Dec 1 2008, 08:09 AM) *
IMMAGINI CON IL FATTORE "X"
La D3x propone tutte le ultime innovazioni tecnologiche nell'ambito della progettazione dei sensori e della tecnologia di elaborazione delle immagini. Concepita per creare file che soddisfino appieno le esigenze del settore pubblicitario e del mercato della fotografia stock, questa fotocamera produce file RAW/NEF a 14 bit da 50MB. Con il software ViewNX a corredo o Capture NX2, i file RAW/NEF possono essere sviluppati con qualit� per raggiungere circa i 140MB su formati TIFF-RGB a 16 bit. I minimi dettagli vengono riprodotti con estrema nitidezza, mentre luci e ombre contengono gradazioni di tonalit� estremamente dettagliate: le immagini che si ottengono sono straordinarie e completamente �nuove�.
IPB ImmagineLa top di gamma Nikon FX - Nikon D3x
vvtyise@tin.it
quante ne prendi, Alfredo?
Mauro Villa
Il funzionamento � identico a quello della D3.
alcarbo
Se fossero state Z tante ....... X non so.
QUOTE(alcarbo @ Nov 30 2008, 12:42 AM) *
MB 1942
Calma con gli entusiami...Il prezzo � notevole: US $7.999,95.
Qui.
alcarbo
QUOTE(vvtyise@tin.it @ Dec 1 2008, 08:29 AM) *
QUOTE(alcarbo @ Dec 1 2008, 08:37 AM) *
QUOTE(MB 1942 @ Dec 1 2008, 08:41 AM) *
Ehhhhh che vuoi che siano !!!!! Poi c'� il cambio favorevole ancora !
E mica c'� una crisi in corso ! Mica che c'� la recessione no ??!! blink.gif
Poi se uno la usa per professione recupera l'iva e tanti profitti... rolleyes.gif
vvtyise@tin.it
e poi � tanto bella! e cos� puoi ache cambiare il pc! e puoi anche prendereti tanti hard disk da 500 GB!
MB 1942
QUOTE(vvtyise@tin.it @ Dec 1 2008, 08:49 AM) *
messicano.gif Sicuro!
Con il mio ci metterei mezz'ora ad aprire uno di quei files!
alcarbo
E' Natale e bisogna dare incremento ai consumi, per il bene di tutti (ora lo dico a mia moglie)..... messicano.gif
vvtyise@tin.it
e mi sono dimenticato le schede di memoria!
alexb61
QUOTE(vvtyise@tin.it @ Dec 1 2008, 09:11 AM) *
Ho sentito che esce una promozione Nikon: chi acquista la D3x diventa azionista della Lexar... laugh.gif (e ci sar� comunque si lamenta perch� preferiva le Sandisk mad.gif )
alexb61
RAW da 50 mega... TIFF da 140... potevano aggiungergli l'uscita S-ATA, cos� attaccavi direttamente l'hard disk alla fotocamera
F.Giuffra
QUOTE(alcarbo @ Dec 1 2008, 08:20 AM) *
Fotoscioppo converte i Nef della mia D90 in tiff a 8 o a 16 bit agevolmente, pesano di pi� dei Jpg e hanno una qualit� maggiore.
Ma la macchina lavora a 12 bit, mentre la D300 a 14 bit, come la D3 e la D3x. Non che faccia una grande differenza.
Hanno solo montato un sensore Sony da 12 su una D3. A parte il raddoppio dei pix che permette di stampare foto con il lato pi� grande di 1,4x, a parte la sensibilit� iso che � scesa, e temo pure la gamma dinamica, tutto � rimasto uguale. La d2x aveva gli stessi pix della D3, ma la latitudine di posa, la sensiblit� iso, la qualit� no.
Mi sembra una concorrente per le medio formato, da usare in sala posa... Ora vorrei vedere come si comporta in un tramonto o in una foto col sole duro, dove serve tanta latitudine di posa.
ANTERIORECHIUSO
QUOTE(alexb61 @ Dec 1 2008, 09:59 AM) *
Gufopica
QUOTE(nippokid @ Dec 1 2008, 05:42 AM) *
Camera: Nikon D3X
Aperture: f/2.8
ISO Speed: 1400
ISO Speed: 1400
Software: Ver.0.66
Sub-Second Time: 08
Color Space: sRGB
Compression: JPEG
Quality: NORMAL
White Balance: AUTO
Focus Mode: AF-S
Lens Type: 14
ottima foto ma penso che anche la d3
la faccia tranquillamente questa foto cosi..
certo la d3x verr� utilizzata in altri campi.
SkZ
http://chsvimg.nikon.com/products/imaging/...p/d3/d3x-sp/en/
quanti in questo forum hanno la capacita' di usare queste risoluzioni? unsure.gif
vvtyise@tin.it
quello che stupisce e che io apprezzo in particolare � il fatto tecnologico che c'� dietro.
Michele Ferrato
QUOTE(Gufopica @ Dec 2 2008, 04:33 PM) *
� la stessissima cosa che ho pensato appena aperta la foto,nulla di trascendentale,cos� quelle sul sito giapponese con la differenza che a 100 iso vedo gi� del rumore ,la D3 per questo � insuperabile.
Michele Ferrato
QUOTE(SkZ @ Dec 2 2008, 05:52 PM) *
