Grazie della segnalazione!
Sul sito Niko-euro per� non � stata riportata ancora nessuna notizia circa l'aggiornamento...se qualcuno sa, parli.
Issues addressed with D2H Firmware Update 2.01
The D2H sometimes froze with uninterrupted navigation between a number of photographs while playback zoom was activated. This problem has been corrected.
When Image review in the playback menu was set to On and a photograph taken just after the camera stopped metering exposure (Auto meter-off activated) was displayed in the camera monitor, there was a significant delay before the shutter was released when the shutter-release button was pressed while this photo was displayed. This problem has been corrected.
When AF-area mode was set to Group dynamic-AF and a6 Focus area illum* in the CSM menu was set to When selected>1 s, the focus area was illuminated for 1 second with a half-press of the shutter-release button. This problem has been corrected.
* Focus area illum is Custom Setting a5 with D2H firmware version 1.0.
A problem that prevented saving of WT-1 settings when the WT-1 was connected to the D2H has been corrected. This problem occurred with the following operations:
-The Wireless LAN Transceiver option was set to Off after connection to an FTP server. WT-1 settings were then adjusted and the D2H was turned off.
-The Wireless LAN Transceiver option was set to Off after connection to an FTP server. WT-1 settings were then adjusted, Transceiver set to On and then set to Off while connecting to a server, and the D2H was turned off.
Incorrect character displays in Spanish, Chinese, and German menus have been corrected.
The following problem that occurred when the camera was controlled from Camera menu>Custom Settings... in Nikon Capture 4 has been corrected. (Macintosh only)
When the Aperture setting option in f5 Command dials was switched from Aperture ring to Sub-command dial, Nikon Capture 4 Camera Control sometimes quit unexpectedly or displayed an inconsistent aperture value.
