Gennaro Ciavarella
su version tracker risulta rilasciato l'aggiornamento di capture per mac os x che risolve i problemi di gestione colore ed altro
riporto
* Improvement to the speed of the displaying and saving of images.
* Support for Mac OS X version 10.4 (Tiger).
* The Color Management tab in the Preferences dialog, has been changed. The Open ColorSync button has been removed and the Default RGB color space and CMYK separation profile are now selected from a pull-down menu.
* An issue which prevented Nikon Capture 4.3 from correctly displaying highlight areas of D2X images taken in Color mode I or II has been corrected.
* D1X RAW images taken with the Nikkor 10.5mm DX Fisheye lens opened as 10MP (4016 × 2616), were always printed as if "Include areas where there is no image data" in the Fisheye Lens palette was turned on. This problem has now been corrected.
* An issue which effected image sharpness, when images were straightened using the "Straighten" option has been corrected.
* An issue which occurred when batch processing, without using the Save Progress window. ICC profiles were embedded despite Embed ICC Profile in the Batch dialog Destination section NOT being checked, has now been corrected.
* A problem in Nikon Capture Camera Control which caused the numbering (naming) of the same image taken in NEF+JPEG, to become inconsistent, has been corrected.
Gennaro Ciavarella
č aggiornato anche in versione win (4.3.1) per ora solo su nikon usa (versione inglese e spagnola)
panim
Ho appena scaricato il Capture 4.3.1. per Mac dal sito europeo(in inglese)
Prestazioni molto migliorate.
Aumento della velocitā appezzabile e soprattutto gestione degli spazi colore (finalmente)
brusa69
QUOTE(panim @ Aug 22 2005, 05:40 PM)
Ciao, vero per le prestazioni ( io win pero' )
ma riguardo lo spazio colore ... lo gestiva anche prima, infatti da tempo ho impostato AdobeRGB :
[attachmentid=25130]
Ho capito male o e' quello che intendevi?
[Edit]
Dubbio : era la versione MAC a non supportarlo?
oesse
la versione MAC OSX non supportava il cambio di spazio colore se installata su tiger.
Ora la gestisce perfettamente!
