QUOTE(fenderu @ Nov 8 2005, 04:00 PM)
A brevissimo sar� pubblicato sul Support Center ufficiale, quindi con caratteristiche e istruzioni in italiano.
lucaoms
QUOTE(matteoganora @ Nov 8 2005, 03:07 PM)
hai gia fatto the installation?
QUOTE(lucaoms @ Nov 8 2005, 04:19 PM)
g_max
QUOTE(matteoganora @ Nov 8 2005, 03:35 PM)
lucaoms
QUOTE(g_max @ Nov 8 2005, 03:58 PM)
attendiamo sue nuove!
Michelangelo Serra
qualcuno sa in cosa estato migliorato il firmware?
g_max
QUOTE(Artephoto @ Nov 8 2005, 04:40 PM)
Dal sito DPREVIEW:
Issues addressed with D2X Firmware Ver. 1.01
Autofocus performance has been increased.
An issue that prevented the AF-assist illuminator from firing when the Speedlights listed below were used has been corrected.
SB-29S, SB-29, SB-23, SB-22S, SB-22, SB-20.
In images captured at a shutter speed of 1/250 s with a Speedlight SB-800, set to Distance-priority manual flash (GN), or Manual flash (M) with flash output set to full (M1/1) mounted on the camera, the top portion was often dark. This issue has been addressed. However, under the circumstances described above only, the guide number is reduced from that of full flash output level by approximately 0.6 EV.
Images captured at white-balance settings of Incandescent, Direct sunlight, Cloudy, Shade, and Choose color temp. tended to have a reddish tint. This issue has been addressed.
Errors in Dutch menus have been corrected.
Michelangelo Serra
ops!!! scusate l'errore grammaticale
Michelangelo Serra
aggiornamento disponibile sul sito europeo
lucaoms
QUOTE(Artephoto @ Nov 8 2005, 05:50 PM)
Disponibile sul sito europeo si ma ti conviene attendere come consiglia matteo
Michelangelo Serra
come mai forse non � da l� che dovremo scarcarlo?
Aggiornata la d2x nessun problema a domani le prove sul campo
r2shot
Ho provato a scaricare l'aggiornamento dal sito europeo e ad aggiornare la
mia D2x, tutto ok. In effetti � il sito di riferimento, solo mancano le istruzioni
in italiano. Comunque formattate due CF dalla macchina e preparate con una parte sola del firmware su ogni CF si parte richiamando l'aggiornamento
dala D2x nel menu "firmware" avendo cura di aggiornare prima la parte A e
successivamente la parte B.
La messa a fuoco mi sembra pi� selettiva e priva di incertezze e � molto pi�
facile ottenere il risultato di una messa a fuoco perfetta. Mi sembra anche che
il rumore allle sensibilit� Iso800 e Hi 1 sia diminuito. Sar� l'effetto firmware??
Ciao Roberto
Michelangelo Serra
ora ci provo anche io
Ci sono anche in Italiano comunque....
In merito a questo firmware:
Questo firmware aggiorna le versioni "A" e "B" dei firmware della Nikon D2X dalla versione 1.00 alla versione 1.01. Quando procedete con l'aggiornamento, assicuratevi di aggiornare sia il firmware "A" che "B". Se queste versioni firmware sono gi� installate nella vostra D2X , non dovete procedere con l'installazione di questo aggiornamento.
Le seguenti migliorie vengono introdotto con il nuovo firmware:
- Migliorate le prestazioni dell'autofocus.
- Corretto un problema che impediva il funzionamento dell'illuminatore ausiliario AF con gli Speedlight SB-29S, SB-29, SB-23, SB-22S, SB-22, SB-20.
- Corretto un problema che provocava una sottoesposizione nella parte superiore dell'immagine utilizzando lo Speedlight SB-800, impostato a Priorit� della distanza in modalit� flash manuale (GN), o in modalit� Manuale (M) con la potenza del lampo impostata su M1/1 alla velocit� di scatto di 1/250. Tuttavia, in circostanze descritte precedentemente, il numero guida � ridotto approssimativamente di 0.6 EV con lampo a piena potenza.
- Corretta una dominante rossa che si presentava nelle immagini quando, queste venivano catturate impostando il bilanciamento del bianco su Incandescenza, Luce del sole diretta, Nuvoloso, Ombra e Temperatura di colore.
- Corretti degli errori riscontrati nel menu in Tedesco
Giorgio Ospici
si in effetti da quello che si legge sia su dprewiew che su nikon cafe'
sembra (dico sembra!!) che chi ha effettuato l'upgrade abbia trovato i suddetti giovamenti riguardo l'AF e gli alti ISO
Giorgio
Michelangelo Serra
ciao seawolf io scaricato tutto e installato va tutto alla grande l'unica cosa mi sa che l'aggiornamento non abbia nessuna miglioria sul valore iso , ma solo su flash, WB e autofocus , sempre se non ho visto e letto male
Giorgio Ospici
ciao Arte
anche io ho appena finito di fare l'aggiornamento
e prima di farlo, dopo aver letto un po' di letteratura in merito al nuovo firmware, ho eseguito un paio di scatti ad iso 800 e hi-1
dopo magari li confronto e se ci saranno eventuali migliorie ti - vi faro' sapere.
l'autofocus a me andava bene anche prima ora pero' sembra che a distanze ravvicinate sia piu' preciso (secondo me)
Giorgio
Michelangelo Serra
ehi! mi sa che avevi propio ragione ho fatto qualche scatto e sembrerebbe che la grana su iso elevati sia migliore li ho postati sul post che interessa la d2x
Giorgio Ospici
speriamo non sia un effetto placebo (per gli alti ISO ovviamente)
Nel mio precedente post sono stato poco chiaro e me ne scuso
ma intendevo dire che chi aveva provveduto all' upgrade del firmware notava un miglioramento (gli utenti di DP rewiev e Nikon Cafe' notavano una resa della grana piu' morbida rispetto alla precedente versione 1.00 ) del rumore ad iso 800 e HI-1
Michelangelo Serra
a me sembra pi� compatta speriamo che non sia il sonno che ho perso in queste notti
Giuseppe Maio
Ho aperto una nuova e dedicata discussione,
in evidenza su http://www.nital.it/forum/index.php?showtopic=24082&st=0.
Potrete continuarla con tutte le necessarie partecipazioni...
Giuseppe Maio
www.nital.it
