Leggendo le prove di Photozone su due nuove ottiche 30 & 50mm sony montate sulla nex7, 24mpx dx, i vantaggi e difetti di una risoluzione cos� elevata si evidenziano.
Riporto quanto scritto su tutte e due le prove di PZ:
The camera sensor of the Sony NEX 7 has a rather difficult resolution characteristic for lenses specifically at large aperture settings - the corner quality is substantially dampened based on what we've seen so far. However, we still feel that it is appropriate to restart our Sony E tests based on this camera. After all this is Sony's flagship model (as of 2012).
The Sony lens is capable of delivering a very sharp center performance straight from f/1.8. This is the good news. The border and corner quality is rather soft here although the NEX 7 sensor has surely is share of responsibility for this. Stopping to f/2.2 lifts the border quality to good levels whereas the corners remain weak. There's a substantial increase in quality at f/2.8 with an excellent center, very good borders and good (just) corners. The peak performance is reached between f/4 and f/8 with a very good image quality across the image frame. Diffraction has an higher impact from f/11 onward.
Riassuendo, tutte e due le ottiche PROVATE SULLA 24MPX hanno una ottima risoluzione al centro con diaframmi intermedi, sia al centro che ai bordi.
Ma... e qui vengono i guai... la diffrazione inizia a risultare evidente (ma non si s� quanto) da f11 in poi, e questo i numeri ce lo dicevano gi�.
Ma quello che non ci si aspettava � che anche a tutta apertura la risoluzione ai bordi precipita per effetto della grande densit� del sensore.
Risultato � che, su una ottica da f1,8 a f22, i diaframmi usabili con risultati buoni ed omogenei sono solo da f4 a f8 ...
Poi ci dicono anche che:
As already mentioned the 24 megapixel sensor of the Sony NEX 7 seems to have a rather difficult characteristic especially regarding its resolution capabilities at the image corners. This behavior has been confirmed by user observations in the meanwhile (feel free to google). This is a bit unfortunate because we feel that the sensor shouldn't have such a deep impact on the lens quality. The lens quality will be somewhat better on Sony's 16 megapixel sensor.
Praticamente non � molto accettabile che un sensore abbia un impatto cosi negativo sulle prestazioni di una lente, sopratutto sugli angoli dell'immagine, che invece migliora con un sensore meno denso quale quello della 16mpx dx.
Mi viene da dire che, per ora, la tecnologia non � ancora matura per una densit� cosi alta.
Max
