prime immagini della custodia sub per d200 della sea & sea qui http://www.seaandsea.co.jp/products/digita...d200/index.html
il testo tradotto dal giapponese da Craig Ruaux su Wetpixel � il seguente
Quick and rather dirty machine translation of the Japanese page. MSRP of 240,000 Yen = ~$2,100 US
As for DX-D200 which concentrates the know-how and technology of the sea and the sea, portable characteristic good quality pursues movement photographing present cheapness, the new model model housing where original technology is condensed. It administers hard alumite processing to the resistance corrosion aluminum alloy in the body material, acquiring strong rigidity. By this structure, it guarantees the efficient space inside the housing body, has contributed to the small size light weight conversion of the body. In addition adding, as for height of degree of completion of the leather tone finish, corrosion-resistant characteristic and resistance abrasiveness you adhere to also the sufficient quality aspect which can be continued to use with hard environment it improved not only, over long time thoroughly. The advanced pickup finder of the easy to see new design, also real function such as leak sensor equipment and the new shutter lever where semi- pushing feeling is easy to know is complete to 4 corners of the camera frame. 2 connectors of N type (2pin connector +5pin connector) you can use the sea and the sea YS series Strobo with standard equipment. If 5pin connector side is used, with TTL converter (for Nikon) connection of option i-TTL automatic modulated light photographing becomes possible. And until recently the abundant NX port in the type similar NX housing series installing possibility. The up-to-date digital one-eyed camera, the quality which responds to the photographing intention which D200 has is shown in the maximum, the expression which the photographing person intends with all subjects and the photographing scene is made possible.
- N type 5pin connector standard equipment
The TTL converter of the option which makes i-TTL automatic modulated light possible (forNikon) you use, connect the sea and the sea genuine Strobo, the Strobo connector (the 5pin connector) side is used. * For you to use, synchronizer cord/code /N is necessary on Strobo side.
- With additional processing the colorful using becomes possible.
Strobo synchronizer connector exchange expense
(5pin -> 2pin) Price undecided 89033
The Strobo connector of the housing surface (5pin connector side) you remodel to the 2pin connector, the sea and sea make YS series Strobo 2 light specification (the 2pin connector �2 basis) it is possible to exchange.
* I-TTL automatic modulated light is not possible.
* For you to use, synchronizer cord/code /N is necessary.
- You can use the lens port and the accessory of the NX housing series.
< Main merit of DX-D200 housing >
* If the TTL converter of option (for Nikon) you use, i-TTL automatic modulated light is possible.
* As for the full aluminum body which can be photographed with the holding which it stabilizes, to the extremity the compact form which is close to the outside sun/size of camera.
* As for body material both front/rear resistance corrosion aluminum alloy. With material feeling improvement strengthening rigidity.
* With new model grip adoption furthermore improvement hold characteristic.
* The pickup finder who becomes the key of digital single-lens reflex photographing approximately 0.66 times. Steadier framing is made possible.
* The new shutter lever which answers the delicate feeling of the fingertip.
* Strobo connector of N type 2 standard equipment. (2pin connector +5pin connector)
* NX lens port, accessory enabled.
* The function of Nikon D200 almost at underwater enabled.
* Equipping the quick shoe which can make the removal and re-installation of the camera simple.
* The lock type pas chin lock which does not have the times when you open carelessly.
* The leak sensor which informs about the flooding of the unlikely event.
< Accessory >
Housing body cap, grip stay, O- ring, silicon grease, camera quick shoe, hexagonal wrench and CR2032 lithium electric battery
< Specification of DX-D200 housing >
* Material: Body/resistance corrosion aluminum alloy, grip/resistance corrosion aluminum die-cast
* Pressure-resistant depth: 60 m 4 substance size: Width 330mm� height 163mm� depth 136mm
* Weight: Approximately 2,500 g (only housing)
* Connector:N type 2 basis (2pin connector +5pin connector)
* Function part:Power switch, shutter, AE/AF lock lever, focusing/zoom dial, main command dial, subcommand dial, focusing mode dial, AF area mode dial, photometry mode dial and exposure revision button, exposure mode/format button and white balance button, picture quality mode/setting reset button, ISO sensitivity button, オートブラケティングボタン, deletion/format button, playback button, menu button and sum nail button, protect/help button, execution button, multiple selector button and AF operation button
Gennaro
