QUOTE(vettori @ Feb 10 2015, 12:04 PM)
Nella press release dicono che non è fatta per foto generiche. Tra l'altro questa 'a' parte da 200 iso. Sicuramente non ha molto senso se non per lo scopo specifico per cui è nata.
costa 2999 caffe inglesi. fonti calumet della mail di oggi.
Type,
Single-lens reflex digital camera
Lens mount,
Nikon F mount (with AF coupling and AF contacts)
Effective angle of view,
Nikon FX format
Effective pixels,
Effective pixels 36.3 million
Image sensor,
Image sensor 35.9 x 24.0 mm CMOS sensor
Total pixels,
37.09 million
Dust-reduction,
System Image sensor cleaning,
Image Dust Off reference data (requires Capture NX-D software)
Storage Image,
size (pixels) • FX format (36 × 24): 7360 × 4912 (L), 5520 × 3680 (M), 3680 × 2456 (S)
• 1.2× (30 × 20): 6144 × 4080 (L), 4608 × 3056 (M), 3072 × 2040 (S)
• DX format (24 × 16): 4800 × 3200 (L), 3600 × 2400 (M), 2400 × 1600 (S)
• 5:4 (30 × 24): 6144 × 4912 (L), 4608 × 3680 (M), 3072 × 2456 (S)
• FX-format photographs taken in movie live view: 6720 × 3776 (L), 5040 × 2832 (M),
3360 × 1888 (S).
• DX-format photographs taken in movie live view: 4800 × 2704 (L), 3600 × 2024 (M),
2400 × 1352 (S).
Note: Photographs taken in movie live view have an aspect ratio of 16:9; A DX-based format is used for
photographs taken using the DX (24×16) 1.5× image area; an FX-based format is used for all other photographs
File format • NEF (RAW): 12 or 14 bit, lossless compressed, compressed or uncompressed; small
size available (12-bit uncompressed only).
• TIFF (RGB)
• JPEG: JPEG-Baseline compliant with fine (approx. 1:4), normal (approx. 1:8) or basic
(approx. 1:16) compression (Size priority); Optimal quality compression available
• NEF (RAW)+JPEG: Single photograph recorded in both NEF (RAW) and JPEG formats
Picture control System
Can be selected from Standard, Neutral, Vivid, Monochrome, Portrait, Landscape,
Flat; selected Picture Control can be modified; storage for custom Picture Controls
Storage Media,
Storage media SD (Secure Digital) and UHS-I compliant SDHC and SDXC memory cards; Type I
CompactFlash memory cards (UDMA compliant)
Dual card slots Either card can be used for primary or backup storage or for separate storage of NEF
(RAW) and JPEG images; pictures can be copied between cards
File system,
DCF 2.0, DPOF, Exif 2.3, PictBridge
Viewfinder,
Viewfinder Eye-level pentaprism single-lens reflex viewfinder
Frame coverage • FX (36×24): Approx. 100% horizontal and 100% vertical
• 1.2× (30×20): Approx. 97% horizontal and 97% vertical
• DX (24×16): Approx. 97% horizontal and 97% vertical
• 5:4 (30×24): Approx. 97% horizontal and 100% vertical
Magnification,
Approx. 0.7× (50 mm f/1.4 lens at infinity, -1.0 m-1)
Eyepoint 17 mm (-1.0 m-1; from center surface of viewfinder eyepiece lens)
Diopter adjustment -3 to + 1 m-1
Focusing screen,
Type B BriteView Clear Matte Mark VIII screen with AF area brackets and framing
grid.
Reflex mirror,
Quick return
Depth-of-field preview,
Pressing Pv button stops lens aperture down to value selected by user (A, M and M*
modes) or by camera (P and S modes)
Lens aperture,
Instant return, electronically controlled
Lens,
Compatible lenses Compatible with AF NIKKOR lenses, including type G, E, and D lenses (some
restrictions apply to PC lenses), DX lenses (using DX (24×16) 1.5× image area) AI-P
NIKKOR lenses, and non-CPU AI lenses (exposure modes A , M and M* only); IX-NIKKOR
lenses, lenses for the F3AF, and non-AI lenses cannot be used: The electronic
rangefinder can be used with lenses that have a maximum aperture of f/5.6 or faster
(the electronic rangefinder supports the 11 focus points with lenses that have a
maximum aperture of f/8 or faster)
Shutter Type,
Electronically controlled vertical-travel focal-plane mechanical shutter, electronic
front-curtain shutter (in mirror-up release mode)
Speed,
1/8000 to 30 s in steps of 1/3, 1/2 or 1 EV, bulb, time, X250
M* mode: 4, 5, 8, 10, 15, 20, 30, 60, 120, 180, 240, 300, 600 or 900 seconds shutter
speed, and Bulb and Time settings are available
Flash sync speed,
X=1/250 s; synchronizes with shutter at 1/320 s or slower (flash range drops at
speeds between 1/250 and 1/320 s).
Release,
Release mode S (single frame), CL (continuous low speed), CH (continuous high speed), Q (quiet
shutter-release), QC (quiet continuous shutter-release), E (self-timer), MUP (mirror up)
Frame advance rate • With EN-EL15 batteries.
(FX/5:4) CL: Approx. 1 to 5 fps, CH: Approx. 5 fps, QC: Approx. 3 fps
(DX/1.2×) CL: Approx. 1 to 6 fps, CH: Approx. 6 fps, QC: Approx. 3 fps
• Other power sources,
(1.2×) CL: Approx. 1 to 6 fps, CH: Approx. 6 fps, QC: Approx. 3 fps
(DX) CL: Approx. 1 to 6 fps, CH: Approx. 7 fps, QC: Approx. 3 fps
Self-timer,
2 s, 5 s, 10 s, 20 s; 1 to 9 exposures at intervals of 0.5, 1, 2 or 3 s.
Exposure Metering mode,
TTL exposure metering using 91K-pixel RGB sensor
Metering method • Matrix: 3D color matrix metering III (type G, E and D lenses); color matrix metering
III (other CPU lenses); color matrix metering available with non-CPU lenses if user
provides lens data
• Center-weighted: Weight of approx. 75% given to 12-mm circle in center of frame;
diameter of circle can be changed to 8, 15 or 20 mm, or weighting can be based on
average of entire frame (non-CPU lenses use 12-mm circle)
• Spot: Meters 4-mm circle (about 1.5% of frame) centered on selected focus point (on
center focus point when non-CPU lens is used)
• Highlight-weighted: Available with type G, E and D lenses (equivalent to centerweighted
when other lenses are used)
Metering range,
Range (ISO 100, f/1.4 lens, 20 °C/68 °F) • Matrix, center-weighted, or highlight-weighted metering : 0 to 20 EV
• Spot metering: 2 to 20 EV
(ISO 100 equivalent, f/1.4 lens, 20°C/68°F)
Exposure meter coupling,
Combined CPU and AI
Exposure Modes,
Programmed auto with flexible program (P); shutter-priority auto (S); aperturepriority
auto (A); manual (M); Long-exposure manual (M*) mode.
Exposure compensation,
-5 to +5 EV in increments of 1/3, ½ or 1 EV
Exposure bracketing,
2 to 9 frames in steps of 1/3, 1/2, 2/3 or 1 EV; 2 to 5 frames in steps of 2 or 3 EV
Exposure lock,
Luminosity locked at detected value with AE-L/AF-L button
ISO sensitivity,
(Recommended Exposure Index) ISO 200 to 12800 in steps of 1/3, 1/2 or 1 EV; can also be set to approx. 0.3, 0.5, 0.7 or 1 EV (ISO 100 equivalent) below ISO 200 or to approx. 0.3, 0.5, 0.7, 1 or 2 EV (ISO 51200
equivalent) above ISO 12800; auto ISO sensitivity control available
Active D-Lighting Can be selected from auto, extra high, high, normal, low or off
ADL bracketing 2 frames using selected value for one frame or 3 to 5 frames using preset values for
all frames.
Focus,
Autofocus,
Nikon Advanced Multi-CAM 3500FX autofocus sensor module with TTL phase
detection, fine-tuning, 51 focus points (including 15 cross-type sensors; f/8 supported
by 11 sensors), and AF-assist illuminator (range approx. 0.5 to 3 m/1 ft 8 in. to 9 ft 10 in.)
Detection range,
-2 to +19 EV (ISO 100 equivalent, 20°C/68°F)
Lens servo • Autofocus (AF): Single-servo AF (AF-S); continuous-servo AF (AF-C); predictive
focus tracking automatically activated according to subject status
• Manual focus (M): Electronic rangefinder can be used
Focus point Can be selected from 51 or 11 focus points
AF-area mode Single-point AF, 9-, 21- or 51-point dynamic-area AF, 3D-tracking, group-area AF,
auto-area AF.
Focus lock,
Focus can be locked by pressing shutter-release button halfway (single-servo AF) or
by pressing AE-L/AF-L button
Flash,
Built-in flash
Manual pop-up with button release and a guide number of approx. 12/39, 12/39 with
manual flash (m/ft, ISO 100, 20°C/68°F)
Flash control,
TTL: i-TTL flash control using 91K-pixel RGB sensor is available with built-in flash;
i-TTL balanced fill-flash for digital SLR is used with matrix, center-weighted, and
highlight-weighted metering, standard i-TTL flash for digital SLR with spot metering
Flash mode,
Front-curtain sync, slow sync, rear-curtain sync, red-eye reduction, red-eye reduction
with slow sync, slow rear-curtain sync, off; auto FP high-speed sync supported
Flash compensation,
-3 - +1 EV in increments of 1/3, 1/2 or 1 EV
Flash bracketing,
Flash-ready indicator
Lights when built-in flash or optional flash unit is fully charged; blinks after flash is
fired at full output.
Accessory shoe,
ISO 518 hot-shoe with sync and data contacts and safety lock
Nikon Creative Lighting System
(CLS) Nikon CLS supported; commander mode option available
Sync terminal ISO 519 sync terminal with locking thread
White balance,
White balance Auto (2 types), incandescent, fluorescent (7 types), direct sunlight, flash, cloudy,
shade, preset manual (up to 6 values can be stored, spot white balance measurement
available during live view), choose color temperature (2500 K to 10000 K); all with
fine-tuning.
White balance bracketing,
2 to 9 frames in steps of 1, 2 or 3
Live View,
Live view modes Live view photography (still images), movie live view (movies)
Live view lens servo • Autofocus (AF): Single-servo AF (AF-S); full-time servo AF (AF-F)
• Manual focus (M)
Live view AF-area mode Face-priority AF, wide-area AF, normal-area AF, subject-tracking AF
Live view autofocus Contrast-detect AF anywhere in frame (camera selects focus point automatically
when face-priority AF or subject-tracking AF is selected)
Movie Movie metering TTL exposure metering using main image sensor
Movie metering method Matrix, center-weighted, or highlight-weighted
Frame size (pixels) and frame rate • 1920 × 1080; 60p (progressive), 50p, 30p, 25p, 24p
• 1280 × 720; 60p, 50p
Actual frame rates for 60p, 50p, 30p, 25p, and 24p are 59.94, 50, 29.97, 25, and
23.976 fps respectively; all options support both high and normal image quality
Movie file format MOV
Video compression H.264/MPEG-4 Advanced Video Coding
Audio recording format Linear PCM
Audio recording device Built-in or external stereo microphone; sensitivity adjustable
Movie ISO sensitivity • Exposure modes P, S and A: Auto ISO sensitivity control (ISO 200 to Hi 2) with
selectable upper limit.
• Exposure mode M and M*: Auto ISO sensitivity control (ISO 200 to Hi 2) available with
selectable upper limit; manual selection (ISO 200 to 12800 in steps of 1/3, 1/2, or 1
EV); can also be set to approx. 0.3, 0.5, 0.7, 1, or 2 EV (ISO 51200 equivalent) above
ISO 12800.
Other movie options Index marking, time-lapse photography
Monitor,
Monitor 8-cm/3.2-in., approx. 1229 k-dot (VGA; 640 × RGBW × 480 = 1,228,800 dots) TFT
monitor with 170° viewing angle, approx. 100% frame coverage, and brightness
adjustment.
Playback,
Playback Full-frame and thumbnail (4, 9 or 72 images) playback with playback zoom, movie
playback, photo and/or movie slide shows, histogram display, highlights, photo
information, location data display, auto image rotation
Interface,
USB SuperSpeed USB (USB 3.0 Micro-B connector); connection to built-in USB port is
recommended.
HDMI output,
Type C HDMI connector
Audio input Stereo mini-pin jack (3.5-mm diameter; plug-in power supported)
Audio output Stereo mini-pin jack (3.5-mm diameter)
Ten-pin remote terminal Can be used to connect optional remote control, optional WR-R10 (requires WRA10
Adapter) or WR-1 Wireless Remote Controller, (M* mode not supported) GP-1/GP-1A GPS Unit, or GPS
device compliant with NMEA0183 version 2.01 or 3.01 (requires optional MC-35 GPS
Adapter Cord and cable with D-sub 9-pin connector)
Supported languages Supported languages,
(may differ by country or area) Arabic, Bengali, Bulgarian, Chinese (Simplified and Traditional), Czech, Danish, Dutch, English, Finnish, French, German, Greek, Hindi, Hungarian, Indonesian, Italian,
Japanese, Korean, Marathi, Norwegian, Persian, Polish, Portuguese (Portugal and
Brazil), Romanian, Russian, Serbian, Spanish, Swedish, Tamil, Telugu, Thai, Turkish,
Ukrainian, Vietnamese.
Power source,
Battery One EN-EL15 Rechargeable Li-ion Battery
Battery pack
Optional MB-D12 Multi-Power Battery Pack with one EN-EL15/EN-EL18a*/EN-EL18*
Rechargeable Li-ion Battery or eight AA-size alkaline, Ni-MH or lithium batteries
* Available separately; Requires optional BL-5 Battery Chamber Cover
AC adapter EH-5b AC Adapter; requires EP-5B Power Connector (available separately)
Tripod socket,
Tripod socket 1/4 in. (ISO 1222)
Dimensions/weight,
Dimensions (W x H x D) Approx. 146 × 123 × 81.5 mm/ 5.8 × 4.9 × 3.3 in.
Weight Approx. 980 g/2 lb 2.6 oz with battery and SD memory card but without body cap;
approx. 880 g/1 lb 15.1 oz (camera body only)
Operating environment,
Temperature: 0 to 40°C/32 to 104°F
Humidity 85% or less (no condensation)
Supplied accessories,
EN-EL15 rechargeable Li-ion battery, MH-25a battery charger, DK-17 eyepiece, UC-E22 USB cable, USB cable clip, HDMI Cable Clip, BM-12 LCD monitor cover.
