Pietro67
al seguente link � possibile scariare l'upgrade a NC 4.1.2. :
[URL=http://support.nikontech.com/... ...=1&p_search_type=3&p_sort_by=dflt]Nikon Capture 4.1.2[/URL]
Serve avere la rel 4.0 o 4.1 installata.
Pietro
Maurizio Firmani
Gi� scaricato! E chi ha anche uno scanner Nikon, � appena uscito l'update alla versione 4.0.2 di Nikon Scan.
benzo@baradelenzo.com
Sai dirmi la differenza con la versione 4.1?
Ciao Enzo
Falcon58
Ciao Enzo,
Queste sono le differenze dell'ultima versione di Nikon Capture (copiato pari pari dal sito a cui f� riferimento Pietro67).
There are numerous feature additions and improvements to this new version of Nikon Capture.
Image files now open faster in the Nikon Capture Editor when using Windows XP and Windows 2000.
The following infrequent problems, with the 'Use Save Progress Window' option in the Preferences dialog, have been corrected.
When Batch processing was performed with 'NEF (Nikon Electronic Image Format)' selected for 'Save as type' and 'Lossless' selected for compression type in the Batch dialog, images were sometimes saved with no compression applied.
When exiting Nikon Capture Editor with unsaved images still open the 'Save changes before closing' confirmation dialog was displayed, however images were not saved even when the 'Yes' button was clicked.
When adjusting image resolution using the Size/Resolution palette with 'Keep my crop' selected, the image display ratio (zoom ratio) was sometimes vastly increased. This problem has been corrected.
When Keywords or Captions was edited, this sometimes prevented the image from being opened in third party image-management applications, this problem has been corrected.
Luciano
