Luceformecolori
Ripreso ora ora da Dpreview.com
Nikon D3 and d300 now support 'D2X mode'
Nikon, obviously realizing that many users of its previous flagship DSLR will be migrating to its successors, has made available 'Picture Controls' aiming to emulate the color reproduction of the D2X(s) on the new D3 and D300. There are three such controls, mirroring the original color modes I to III. These settings may be used as a base point to add further tweaks and should prove a major time-saver to photographers wishing to upgrade their camera bodies and continue with their existing workflow. The Picture Controls are available now via Nikon's website, links after the jump."
Che tradotto...
"Nikon, rendendosi chiaramente conto che molti possessori dei precedenti modelli delle Ammiraglie migreranno alle nuove generazioni, ha reso disponibili dei nuovi "Picture Control" con lo scopo di riprodurre i Modi Colore delle D2x(s) sulle nuove D3 e D300.
I nuovi "Picture Control" sono tre, analogamente alle modalit� colore originali, I-II e III.
Queste impostazioni possono essere usate come base di partenza per ulteriori regolazioni e dovrebbero portare ad un notevole risparmio di tempo ai fotografi che desiderano passare ai nuovi corpi macchina mantenendo i propri flussi di lavoro.
I nuovi "Picture Control sono disponibili presso il sito web Nikon.
"Details
When these optional Picture Controls are registered with the D300 digital-SLR camera, which supports the Picture Control System, color reproduction simulating that of the D2X and D2XS is possible;
This is a set of three optional Picture Controls, one for each of the three D2X/D2XS Color mode settings;
When the optional Picture Controls are registered with the D300 digital-SLR camera, color reproduction simulating that of images captured with the D2X and D2XS is possible, and custom Picture Controls can also be created based on these optional Picture Controls;
For black-and-white images, use the standard Monochrome Nikon Picture Control;
D2XMODE1: This optional Picture Control simulates color reproduction at a D2X/D2XS Color mode setting of I. Skin tones and gradations are reproduced naturally with rich reproduction of tones;
D2XMODE2: This optional Picture Control simulates color reproduction at a D2X/D2XS Color mode setting of II. This optional Picture Control is suited to images that will be extensively processed or retouched;
D2XMODE3: This optional Picture Control simulates color reproduction at a D2X/D2XS Color mode setting of III. Choose for nature or landscape shots. Greens and blues are vividly reproduced.
*To achieve a level of brightness similar to that of images captured with the D2X/D2XS, set Picture Control Brightness to -1.
Color reproduction precisely the same as that achieved with D2X/D2XS Color mode settings I, II, and III is not guaranteed with the three D2XMODE1, D2XMODE2, and D2XMODE3 optional Picture Controls.
*D2XMODE1-3 optional Picture Controls must be registered with the camera before custom Picture Controls, based on D2XMODE1-3, can be created using Capture NX or ViewNX and registered with the camera."
Dettagli:
- Registrando questi Picture Controls sulla D300/D3, la riproduzione del colore sar� resa possibile anche emulando quanto operato dalle D2X(s)
- Il Set consiste di tre Picture Controls, uno per ogni settaggio del Modo Colore
- Con la registrazione di questi Picture Controls, � possibile simulare la riproduzione del colore delle immagini come operato dalle D2x(s).
Possono essere creati nuovi Picture Controls personalizzati basandosi su queste impostazioni.
- Per immagini in B/N usare il Picture Control Nikon Monocromatico Standard
- D2XMODE1: Simula la riproduzione colore di una D2X(s) impostata a Modo Colore I. Tonalit� della pelle e relative gradazioni cromatiche sono riprodotte naturalmente con una ricca gamma di sfumature.
- D2XMODE2: Simula la riproduzione colore di una D2X(s) impostata a Modo Colore II. Modalit� colore indicata per immagini che debbano essere intensivamente ritoccate od elaborate.
- D2XMODE3: Simula la riproduzione colore di una D2X(s) impostata a Modo Colore III. Modalit� colore indicata per scatti naturalistici o paesaggistici. Riproduzione vivida della gamma del Verde e del Blu.
*Per raggiungere un livello di luminosit� simile a quello delle immagini prodotte dalle D2X(s), impostare la Luminosit� a -1
Non si garantisce la precisa corrispondenza cromatica tra le modalit� simulate (tramite Picture Control) e quelle originali delle D2X(s).
* I Picture Controls D2XMODE1-3 debbono essere registrati sul corpo macchina prima che altre personalizzazioni su essi basate possano essere create usando Capture NX o View NX e successivamente salvate sul corpo macchina stesso."
Link Originale
studioraffaello
QUOTE(fire.hawk @ Nov 27 2007, 05:41 PM) *
Che tradotto...
"Details
Dettagli:
Link Originale
_Lucky_
puo' darsi che non abbia capito tutto l'articolo citato, ma se non interessa il file jpg prodotto in macchina, si puo' fare lo stesso direttamente sui file NEF di qualunque macchina, usando l'ultima release di ViewNX che consente di applicare alla foto i tre picture control "like" D2x....
Luciano
manthis
scusate....ci ho capito ben poco......ma come si fa a trasferire nella fotocamera questi Picture Control
scusate la mia ignoranza
Denis Calamia
_Led_
QUOTE(manthis @ Nov 30 2007, 11:13 AM) *
RTFM page 160 (english user manual)!!!!
Li devi caricare dal computer su una CF e poi dalla CF sulla macchina.
Copiatevi anche quelli "lisergici" di Ken Rockwell!!!
lhawy
ma se uno vuole i modi della d2x.......perch� non si tiene la d2x? tongue.gif
alcarbo
QUOTE(manthis @ Nov 30 2007, 09:13 AM) *
Mi associo. Ora rileggo e cerco di capire... ma...
bluejens
aiuto sono in confusione totale con la d300 non riesco a caricare il profilo della d200
capreolus
Che tradotto...
"Details
Dettagli:
Link Originale
grazie.gif Grazie, download eseguito come descritto dalle istruzioni nel sito, caricati i mode in oggetto. Ora mi resta che provarli hmmm.gif
Luceformecolori
Domani studio come fare e posto due dritte.
Stasera � il mio anniversario di matrimonio e non � proprio cosa!!
benzo@baradelenzo.com
Scusate la mia profonda ignoranza, non sono molto tecnico ma non capisco una cosa.
Se compero la D3 per quale motivo dovrei scaricarmi le curve della D2X per simulare il colore di quest'ultima? A questo punto rimango con la D2X ma se compero la D3 presumo che sia superiore
Non capisco !! Si parla poi di flussi di lavoro. Che ha a che vedere questo con il profilo colore della macchina???
Ciao Enzo
Luceformecolori
Se ci si abitua alla resa cromatica di una macchina (ad es la D2X) e si desidera sfruttare tutti i vantaggi della nuova nata mantenendo l'impostazione della precedente, in questo caso servono i profili colore.
Ovviamente tutti i vantaggi della D3/D300 saranno mantenuti, non � detto che la resa cromatica impostata di default su queste ultime sia quella desiderata.
Se a me va bene la D2x ma non il suo rumore, prendo la D3, ho meno rumore ed il FF, ma continuo a lavorare con la stessa impostazione colore usando l'apposito file.
Due piccioni con una xxx.
manthis
FATTO!!
grazie a tutti
