QUOTE(Franco_ @ Feb 8 2008, 09:09 AM)
Non ci sei riuscito nemmeno con GexifView ?
felice possessore di una d2h da qualche ora; hio scaricato GexifView ma non riesco a trovare il numero degli scatti?? mi date una mano??
File = F:\DCIM\107NCD2H\RAP_0002.NEF
Section count = 1
Section[ 1] - 0x00 - - Offset : 0 0x000000 - Size: 0 0x0000
-- EXIF-Info ---------------------------
ErrStr = <none>
Intel Byte Order
-- EXIF-Data ---------------------------
Read Tiff : 24=Directory 24 entries
New Subfile Type : 1
Image Width : 160
Image Length : 120
Bits Per Sample : 8, 8, 8
Compression : 1=TIFF
Photometric Interpretation : 2=RGB
Make : NIKON CORPORATION
Model : NIKON D2H
Strip Offsets : 106122
Orientation : 1=Normal 0�
Samples Per Pixel : 3
Rows Per Strip : 120
Strip Byte Counts : 57600
X Resolution : 300/1=300
Y Resolution : 300/1=300
Planar Configuration : 1=Chunky Format
Resolution Unit : 2=Inch
Software : Ver.2.01
Date Time : 2008:02:18 15:55:01
Sub IFD : 163722
Reference Black White : 0/1, 255/1, 0/1, 255/1, 0/1, 255/1
Exif Offset : 460
Date Time Original : 2008:02:18 15:55:01
TIFF/EP Standard ID : 1, 0, 0, 0
Next IFD : 0=no next
Sub IFD : 17=Directory 17 entries
New Subfile Type : 0
Image Width : 2496
Image Length : 1648
Bits Per Sample : 12
Compression : 34713=34713 ???
Photometric Interpretation : 32803=32803 ???
Strip Offsets : 163948
Samples Per Pixel : 1
Rows Per Strip : 1648
Strip Byte Counts : 2764144
CFA Repeat Pattern Dim : 2, 2
CFA Pattern : 1, 2, 0, 1
Sensing Method : 2
Exif Offset : 33=Directory 33 entries
Exposure Time : 10/300=1/30 sec [1/30,00]
F Number : 45/10=F4,5
Exposure Program : 3=Aperture Priority
ISO Speed : 200
Date Time Digitized : 2008:02:18 15:55:01
Exposure Bias Value : 0/6=0 EV
Max Aperture Value : 0/10=F1,0
Metering Mode : 2=Center Weighted Average
Light Source : 3=Tungsten
Flash : 0=Off
Focal Length : 3000/10=300,00 mm
Maker Note : 78, 105, 107, 111, 110, 0, 2, 0, 0, 0, 77, 77, 0, 42, 0, 0, 0, 8, 0, 40, 0, 1, 0, 7, 0, 0, 0, 4, 48, 50, 48, 48, 0, 2, 0, 3, 0, 0, 0, 2, 0, 0, 0, 200, 0, 4, 0, 2, 0, 0, 0, 8, 0, 0, 1, 238, 0, 5, 0, 2, 0, 0, 0, 13, 0, 0, 1, 246, 0, 6, 0, 2, 0, 0, 0, 7, 0, 0=Nikon.....MM.*.....(........0200...........�......
User Comment : ASCII... =ASCII...:
Sub Sec Time : 16
Sub Sec Time Original : 16
Sub Sec Time Digitized : 16
Related Sound File :
Sensing Method : 2=OneChipColorArea
File Source : 3=Digital Still Camera
Scene Type : 1=Directly Photographed
CFA Pattern : 0, 2, 0, 2, 1, 2, 0, 1=........
Custom Rendered : 0=Normal process
Exposure Mode : 0=Auto
White Balance : 1=Manual
Digital Zoom Ratio : 1/1=1/1x
Focal Length in 35mm Film : 450=450,00 mm
Scene Capture Type : 0=Normal
Gain Control : 0=None
Contrast : 0=Normal
Saturation : 0=Normal
Sharpness : 2=Hard
Subject Distance Range : 0=Unknown
-- Maker Specific Data: Nikon3 ---------
Header/Offset : Nikon.....MM.*....
Nikon3 Makernote : 40=Directory 40 entries
Makernote Version : 48, 50, 48, 48=0200
ISO Used : 0, 200
Quality : RAW [raw: 52 41 57 20 20 20 20 00 ]
White Balance : INCANDESCENT [raw: 49 4E 43 41 4E 44 45 53 43 45 4E 54 00 ]
Sharpening : HIGH [raw: 48 49 47 48 20 20 00 ]
Focus Mode : MANUAL [raw: 4D 41 4E 55 41 4C 00 ]
Flash Setting : NORMAL [raw: 4E 4F 52 4D 41 4C 20 20 20 20 20 20 00 ]
Auto Flash Mode : [raw: 20 20 20 20 20 20 20 20 00 ]
White Balance Bias : 0
Unknown : 0, 1, 6, 0=....
Exposure Difference : 0, 1, 12, 0=....
Thumbnail Offset : 7118
Flash Compensation : 0, 1, 6, 0=....
ISO Requested : 0, 200
Tone Compensation : NORMAL [raw: 4E 4F 52 4D 41 4C 20 20 00 ]
Lens Type : 1= 1 ???
Lens Information : 0/10, 0/10, 0/10, 0/10=0,0-0,0(mm) F0,0-F0,0
Flash Used : 0=Flash Not Used
Auto Focus Position : 0, 0, 0, 0=....
Bracketing Mode : 0=no bracketing - Single frame
Lens Stops : 0, 1, 12, 0=....
NEF Decode Table1 : 73, 16, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255=I.................................................
Color Mode : MODE1 =Mode 1 (sRGB)
Lighting Type : NATURAL [raw: 4E 41 54 55 52 41 4C 20 20 20 20 00 ]
Unknown : 48, 49, 48, 50, 12, 14, 13, 13, 13, 12, 6, 249, 8, 15, 89, 16, 142, 16, 56, 1, 67, 3, 251, 0, 232, 0, 56, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, =0102..........Y...8.C.....8.......................
Hue Adjustment : 3
Nikon3-0x0093 : 1
Noise Reduction : OFF [raw: 4F 46 46 20 00 ]
Nikon3-0x0096 : 68, 16, 1, 72, 1, 72, 1, 72, 1, 72, 2, 171, 0, 0, 0, 1, 0, 2, 0, 3, 0, 4, 0, 5, 0, 6, 0, 7, 0, 8, 0, 9, 0, 10, 0, 11, 0, 12, 0, 13, 0, 14, 0, 15, 0, 16, 0, 17, 0, 18, 0, 19, 0, 20, 0, 21, 0, 22, 0, 23, 0, 24, 0, 25, 0, 26, 0, 27, 0, 28, 0, 29, 0, 30, 0, 31=D..H.H.H.H.�......................................
Color Balance : 48, 49, 48, 50, 0, 0, 0, 0, 0, 12, 1, 114, 1, 0, 1, 0, 2, 42, 3, 3, 0, 1, 0, 0, 0, 1, 0, 1, 12, 4, 3, 31, 3, 27, 4, 227, 4, 56, 4, 82, 2, 121, 4, 39, 4, 98, 0, 16, 2, 82, 0, 77, 0, 150, 0, 29, 2, 18, 2, 197, 0, 216, 0, 118, 2, 48, 2, 69, 0, 0, 4, 43, 0, 11=0102.......r.....*...................8.R.y.'.b...R
Lens Data : 48, 49, 48, 49, 0, 0, 0, 0, 0, 0, 142, 0, 0, 0, 0, 0, 0, 0, 52, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0=
NEF Thumbnail Size : 1248, 826
Sensor Pixel Size : 94/10, 94/10 [raw: 00 00 00 5E 00 00 00 0A 00 00 00 5E 00 00 00 0A ]
Nikon3-0x00A0 : PKX2318232640717206 [raw: 20 50 4B 58 32 33 31 38 32 33 32 36 34 30 37 31 ..]
Unknown : 0
Unknown : 173559
Unknown : 73242
Total Shutter Releases : 246801
Unknown : 48, 49, 48, 48, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0=0100................
Nikon3-0x00AF : 48, 49, 48, 48, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0=0100....................
-- No Thumbnail ------------------------
-- EXIF Summary -(short) ---------------
RAP_0002.NEF 2859k 2008:02:18 160w 120h
-- EXIF Summary -(long) ----------------
File Name : RAP_0002.NEF
File Size : 2859k
File Date : 18/02/2008
Photo Date : 2008:02:18 15:55:01
Make (Model) : NIKON CORPORATION (NIKON D2H)
Dimensions : 160 x 120
Exposure Time : 1/30 sec [1/30,00]
Focal Length : 300,00 mm
F Number : F4,5
ISO : 200
Flash : No
-- Show specific items found in image --
** Widest Aperture is F1,0
** Light Meter mode is Center Weighted Average
grazieeeeeee!!!
