Pagine: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 700, 701, 702, 703, 704, 705, 706, 707, 708, 709, 710, 711, 712, 713, 714, 715, 716, 717, 718, 719, 720, 721, 722, 723, 724, 725, 726, 727, 728, 729, 730, 731, 732, 733, 734, 735, 736, 737, 738, 739, 740, 741, 742, 743, 744, 745, 746, 747, 748, 749, 750, 751, 752, 753, 754, 755, 756, 757, 758, 759, 760, 761, 762
DEVILMAN 79
QUOTE(MrFurlox @ Oct 30 2012, 01:59 AM) *
eccomi pronto per la birretta ! toglimi una curiosit� io volevo mettermi in casa un paio di stufette a pellet ( staccate dall' impianto dei termosifoni ) ma le posso istallare senza "cappa" della serie : comprata , buttata in mezzo alla camera , caricatata e accesa ?
oppure devo avere qualche accortezza particolare ? immagino che la tua sia grandicella ( 110-120 x 80-90 x 60-70 ? ) e sia attaccata ad una parete ma il principio di funzionamento non dovrebbe essere molto diverso ...anzi laugh.gif
No, hanno tutte comunque bisogno di un camino, ovviamente il pellet brucia e f� fumi...
La mia � su una parete, ho preso una slim, praticamente � circa 100x100 e profonda 30cm (compresi i tubi), inoltre � attaccata ai termosifoni, ora in questi giorni, la proviamo per bene e vediamo come v�.
Sin'ora ho usato la caldaia a gas con le bombole, la spesa per� � diventata insostenibile, 300 euro al mese x 4ore complessive al giorno di pseudo-riscaldamento....
Quelle classiche ventilate, fanno parecchio caldo, la mia un p� meno(comunque tanto) ma, almeno mi permette di metterla in posti meno strategici ma pi� comodi e comunque di scaldare a distanza stanze chiuse.
Vincenzo.
MrFurlox
QUOTE(DEVILMAN 79 @ Oct 30 2012, 02:20 AM) *
Vincenzo.
si il problema dello pseudo-riscaldamento lo conosco bene cerotto.gif noi rimediamo con le pompe di calore usate al bisogno ma non � ne una soluzione pratica ( appena le spegni cala il gelo e non le puoi tenere accese troppo perch� seccano l' aria in maniera incredibile ) ne economica ( puntualmente sono accese di giorno o di sera tardi e la bolletta va su presto ) .....
insomma cercavo una soluzione alternativa che forse sarebbe anche facilmente posizionabile biggrin.gif
vabb� va ti saluto vado a letto che domani mi devo anche svegliare presto dry.gif buonanotte !!!!
alcarbo
Apro e poi faccio quello che si fa ma che in questo bar non si deve mai dire: vado a letto a provare a dormire, siccome la notte scorsa � durata solo due ore a causa di un mal di stomaco per aver bevuto gli intrugli (evidentemente mal preparati) consigliati tutte le sere da Davide, nel senso che li ho mescolati tutti insieme. ciao
MrFurlox
QUOTE(alcarbo @ Oct 30 2012, 11:07 PM) *
ciao Alfredo mi sa che stasera a trasgredire la regola di questo bar saremo in due laugh.gif
davidebaroni
DEVILMAN 79
'sera a tutti, birretta ed un po' di meritato riposo....
E' una settimana di sonno questa, st� diventando tutt'uno col divano....
Vincenzo.
MrFurlox
sera a tutti !!!!
davidebaroni
Ma qualcosa di caldo lo prendo volentieri... Cioccolata con panna? tongue.gif
MrFurlox
QUOTE(davidebaroni @ Nov 1 2012, 11:36 PM) *
benissimo ne faccio due .... inizio a chiedere al cittadinanza inglese cos� posso ordinare una birra calda in attesa che arrivino Matteo , Vincenzo e gli altri laugh.gif
davidebaroni
CIttadinanza inglese? Brrrrr... In Inghilterra secondo me meglio un punch al rum o un grog, belli caldi. Sempre che mi ricordi correttamente cosa sono e come sono fatti... laugh.gif
MrFurlox
QUOTE(davidebaroni @ Nov 1 2012, 11:41 PM) *
davidebaroni
RIdi, ridi... Io mi ricordo ancora un'estate in Scozia, 14-15� e tutti a dire "Wow, che bella estate calda che abbiamo quest'anno!"... Estate calda un corno, quello era un autunno cos� cos�! texano.gif
MrFurlox
QUOTE(davidebaroni @ Nov 2 2012, 12:05 AM) *
cmq io la cittadinanza la volevo prendere solo per poter bere la birra calda senza schifarmi biggrin.gif
DEVILMAN 79
Buonasera a tutti....
QUOTE(MrFurlox @ Nov 1 2012, 11:39 PM) *
Ma come fai..... per me la birra, rigorosamente fredda, anche fosse al Polo....
Vincenzo.
Cary
DEVILMAN 79
QUOTE(Cary92 @ Nov 2 2012, 02:10 AM) *
Niente ritardo, stavo stappando una birra, ti unisci a noi???
Vincenzo.
MrFurlox
QUOTE(DEVILMAN 79 @ Nov 2 2012, 02:10 AM) *
Vincenzo.
infatti non faccio ... ecco perch� speravo che prendendo la cittadinanza inglese potessi riuscire a trangugiare quel nettare trasformato in sbobba biggrin.gif
vabb� va ti faccio compagnia due belle birrette ghiacciate
nono macch� ritardo , buonasera !!!
Cary
QUOTE(DEVILMAN 79 @ Nov 2 2012, 02:12 AM) *
Vincenzo.
Vi tengo compagnia (ma niente birra per me wink.gif )
QUOTE(MrFurlox @ Nov 2 2012, 02:13 AM) *
DEVILMAN 79
"FUORI ORARIO"
Messaggio per Alfredo: Svuota la cartella MP!!!! Non riesco ad inviartene.
Oggi parto e rientro domenica sera, se non ti risp. subito � perch� non ho connessione.
Scusate il fuori orario, quando rientro un giro di birra per tutti ed un infuso per Davide.... tongue.gif
Vincenzo.
davidebaroni
QUOTE(MrFurlox @ Nov 2 2012, 12:16 AM) *
� vero la tua temperatura ideale � 24 !!!!
No... Non � la mia temperatura ideale. E' la mia temperatura minima di sopravvivenza! laugh.gif
Andiamo pure di cioccolata calda con panna, please... Vorrei fare il BAGNO. tongue.gif
MrFurlox
QUOTE(davidebaroni @ Nov 2 2012, 11:05 PM) *
Aperto!
ah ok quindi non sono poi tante le parti del mondo dove potresti vivere tutto l' anno biggrin.gif
Brunosereni
Ormai ti � rimasto il vizio... come faceva un certo twinsouls dall'altro capo del mondo.
E' sempre un piacere trovarti dietro il banco. Stasera pago io, vedi il post.
jones4
QUOTE(MrFurlox @ Nov 2 2012, 11:41 PM) *
Eccomi!
Sera Mr,Davide e Bruno.
Appena di ritorno da un mondo fantastico...
quello del"Cirque du soleil" mi sono tuffato in "alegria"
Scordatevi di fare la bencheminima foto!
Bruno se � quello che penso io complimenti!!!
Matteo
DEVILMAN 79
'sera a tutti,
vi scrivo dal'interno delle "cantine Antinori", stiamono qui da amici (l'agronomo e la compagna).....
Stasera, niente birra, vado a vino pregiato........ Marco, che tropea che ci prenderemmo insieme qui....
Vincenzo.
MrFurlox
QUOTE(jones4 @ Nov 3 2012, 12:15 AM) *
Eccomi!
Matteo
wub.gif prima o poi andr� in Canada a vederli .... � un pallino che ho da tempo , � il mio circo preferito ( se non l' unico che mi piace )
piuttosto "Alegria" � uno spettacolo di qualche anno fa ce l' hai su DVD ?
QUOTE(DEVILMAN 79 @ Nov 3 2012, 12:17 AM) *
'sera a tutti,
Vincenzo.
ma sei all' agriturismo di cui mi avevi parlato ??? bhe allora alza un calice ( vabb� non dico c@azzate facciamo 2-3-4-5-6 laugh.gif ) anche per me wink.gif
Cary
Hola! Giornata passata a casa con la febbre alta ��
jones4
QUOTE(MrFurlox @ Nov 3 2012, 12:22 AM) *
FUORI ORARIO!!!!
Scusate gente prometto che non lo faccio pi�!
Marco in questi mesi stanno riproponendo lo spettacolo in Italia(io l'ho visto a Pesaro) ed ogni 2 anni fanno un tour con date qui da noi,quindi non serve andare in Canada anche se sarebbe indubbiamente migliore! biggrin.gif
Questo � il terzo che vedo dopo "delirium" e "saltimbanco" ed ancora non ne sono sazio!!!
Qui le date con i prezzi: http://www.ticketone.it
Matteo
alcarbo
Ciao Matteo, Marco, Vincenzo, Davide, Cary e chi altri quelli della pagina precedente. Sono stato assente per un giorno intero.
Cary rimettiti in fretta. Lo sai che uno dei vantaggi dell'invecchiare e che, siccome con il tempo ti carichi di anticorpi (e di tante altre porcherie) alla mia et� le influenze non vengono pi�; del resto se venissere sarebbero letali.
E poi lo sapevi che fanno fare i vaccini agli anziani non per prevenire le influenze ma per farne crepare qualcuno ed alleggerire cos� i costi del Servizio Sanitario Nazionale ? Negli ultimi vent'anni le uniche influenze che ho avuto mi sono venute quando anni orsono mi sono fatto convincere a fare i vaccini.
Poi mio padre (che era un medico all'antica, tanto � vero che ha pensato di morire 15 anni fa) mi disse di farmi furbo e di non fare i vaccini.
Cos� di influenze non ne ho pi� avute.
DEVILMAN 79
'sera a tutti, tornato quasi sobrio dal giro in "continente", sicuramente stanchissimo per il tour de force fatto a vino buono e cinghiale....
Abbiamo fatto un sacco di chilometri tra Orbetelo dove c'era "Gustatus" e Firenze...
Ho finalmente preso gli album del mio matrimonio e.... non siamo molto contenti mad.gif .
X Marco, nessun agriturismo, eravamo a casa di questi amici che lavorano in due cantine diverse (sempre Antinori), in uno dei casali delle cantine....
Ps: non posto foto perch� non ero in condizione di scattare tongue.gif ...
Vincenzo.
Cary
Buonasera!
QUOTE(alcarbo @ Nov 4 2012, 11:40 AM) *
Alcarbo, la febbre � passata abbastanza velocemente (e senza medicinali...)
QUOTE(DEVILMAN 79 @ Nov 4 2012, 11:02 PM) *
Vincenzo.
Ciao Vincenzo! Non contento degli album del tuo matrimonio? hmmm.gif Hanno fatto quelle bellissime composizioni di 5 o 6 foto, con colore selettivo e altre cose di questo genere? Girando qualche "fiera nozze" ho visto che queste cose vanno molto di moda messicano.gif smilinodigitale.gif
davidebaroni
...E anche buonanotte, mi faccio un infuso di mele, cannella e garofano e vado a dormire. cerotto.gif
MrFurlox
sera a tutti !!!!
DEVILMAN 79
QUOTE(Cary92 @ Nov 4 2012, 11:26 PM) *
Buonasera!
No, anzi...foto stampate singolarmente su carta fine art matte, 30x40 album matrimonio, 25x35(circa) quello del ricevimento e 18x25 (circa) i 2 per i genitori.
Non mi piace la scelta delle foto, ma per questo, sono stato io ad affidarmi a lui, la cosa che mi ha fatto parecchio innervosire � che la maggior parte hanno i bianchi parecchio bruciati, del vestito di lei non si distingue quasi nulla.
Ho anche i jpeg non lavorati che sono molto pi� bruciati, questo vuol dire che sono cos� perch� non riesce pi� a recuperare nulla di raw.
Vincenzo.
Cary
QUOTE(DEVILMAN 79 @ Nov 4 2012, 11:45 PM) *
Vincenzo.
MrFurlox
Vincenzo.
brutte cose !!! pensa come ha lavorato bene !!!!
ovviamente i raw non te li dar� neanche sotto tortura ma sui jpeg non riesci a farci nulla ?
DEVILMAN 79
QUOTE(Cary92 @ Nov 4 2012, 11:49 PM) *
QUOTE(MrFurlox @ Nov 4 2012, 11:57 PM) *
Ha tenuto fuori dall'album scatti bellissimi.... proprio non ci arrivo a capire, visto che ce ne sono alcuni duplicati.
Avevo scelto lui, proprio per non avere brutte sorprese, posso capire che un matrimonio che non riesce coi fiocchi ci pu� stare anche con un professionista, per� l'esposimetro (usava Canon 5MkII e 5MkIII)gli ha cannato parecchie foto a giudicare dagli exif....
Giulia mi f� ancora pi� rabbia, quando ha visto gli scatti prima della stampa, se ne era accorta e non ha detto nulla n� a lui n� a me.
Ormai � cos�, appena posso provo a recuperare qualcosa con LR...
Vincenzo.
jones4
Sera a tutti nottambuli!
Io intanto propongo un giro di birra...sempre se gradite!!!
Vincenzo...situazione spiacevole,non riesci proprio ad accordarti?
Alla fin fine ne va anche della sua reputazione di professionista...
MrFurlox
QUOTE(DEVILMAN 79 @ Nov 5 2012, 12:10 AM) *
Vincenzo.
ma scusa gli scatti non li avete scelti voi ?
DEVILMAN 79
QUOTE(MrFurlox @ Nov 5 2012, 12:19 AM) *
Da accordi iniziali, gli scatti li doveva scegliere lui, visto che � un reportage, avrebbe avuto una visione meno emozionale della mia. Sapendo comunque che a Giulia qualcosa non sarebbe andato gi�, lui ha aspettato il nostro assenso prima di mandarli in stampa e quando Giulia � andata a vedere gli scatti finali, non ha detto nulla e li ha fatti stampare. qualcosa avevo visto anche io e non erano cos� male, in stampa per� sono proprio bruciati, cos� come sul mio monitor...
Ora, o ha il monitor scalibrato lui oppure hanno fatto casino in stampa.
Quando ho un attimo ne carico qualcuna....
Ora vado a letto, sono veramente stanco e domani mi aspetta il lavoro.
'notte ragazzi...
Vincenzoi.
MrFurlox
QUOTE(DEVILMAN 79 @ Nov 5 2012, 12:47 AM) *
'notte ragazzi...
Vincenzoi.
notte !!! io comunque un "contestazione" proverei a fargliela ... magari in maniera civile , ma ci proverei !:)
alcarbo
MrFurlox
aperto !!!!
sera a tutti !!!
davidebaroni
Stasera mi serve una cosa rinfrescante... un bel t� alla menta, per esempio. tongue.gif
MrFurlox
QUOTE(davidebaroni @ Nov 5 2012, 11:58 PM) *
davidebaroni
Buonanotte a tutti!
jones4
QUOTE(alcarbo @ Nov 5 2012, 07:29 PM) *
Sera Marco,Davide
Cary
jones4
QUOTE(Cary92 @ Nov 6 2012, 12:58 AM) *
sera!
MrFurlox
MrFurlox
