Pagine: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 700, 701, 702, 703, 704, 705, 706, 707, 708, 709, 710, 711, 712, 713, 714, 715, 716, 717, 718, 719, 720, 721, 722, 723, 724, 725, 726, 727, 728, 729, 730, 731, 732, 733, 734, 735, 736, 737, 738, 739, 740, 741, 742, 743, 744, 745, 746, 747, 748, 749, 750, 751, 752, 753, 754, 755, 756, 757, 758, 759, 760, 761, 762
gbarbiera
Innanzi tutto buonasera ad Alcarbo, Gianci, Nippokid ed agli altri che ci raggiungeranno.
Da un po di tempo gironzolando nei 3d tecnici mi sono venute in mente due idee che definire stupide è riduttivo, sarebbe più appropriato un termine che inizia per s e finisce per a (sciocchezza forse, non direi).
La prima : Ci sono molti utenti che lamentano spesso a torto qualche volta a ragione di problemi più o meno inficianti l'uso delle loro macchine o dei loro obbiettivi, costosi e non. A questo punto si potrebbe creare una OnLus che avrebbe come fine istituzionale quello di ritirare gratuitamente da costoro quanto scartato e redistribuirlo tra coloro che essendo poveri sia di soldi sia di conoscenze fotografiche sarebbero ben felici di averlo. Datemi un 24-70 o un 14-24 o un 70-200 con back/front focus, poca nitidezza, flare e chi nè ha più nè metta, li prendo tutti e ringranzio calorosamente.
La seconda : molti 3d si trasformano in risse verbali eccezionali. Perchè non creare un premio per i rissaioli più bravi e frequenti. Premio un tappo copri corpo e due tappi anteriore/posteriore copri obbiettivo.
Poi visto che ho sparato tali c.....e pongo una domanda dopo la quale sarete in diritto di sentirvi liberi di mandarmi a spigolare.
Domanda : le foto che posto sono solo sul PC da cui scrivo e sono capace solo di inserirle come allegati. Come devo fare perchè appaiano nel testo già visibili tipo quelle postate da voi.
Stasera mi sento un pochino alcolico per gradirei un Cuba Libre con tanto ghiaccio e poco Rum da sorseggiare fumando il mio solito Antico Toscano.
gianci
cmq è vero gli acquisti notturni sono proprio pericolsi, sembra quasi che ha una certa ora tirassi il freno a mano al cervello, e la parte che ragiona nn fà bene il suo lavoro.... wacko.gif
alcarbo
Grazie per la bevuta
Non esco a lavorare senza farvi partecipi del mio nuovissimo totalmente rinnovato corredo
AF-Nikkor 50mm f/1.4 D
AF-Nikkor 50mm f/1.8 D
AF DX Fisheye Nikkor 10,5mm f/2,8 G IF-ED
AF-Nikkor 14mmf/2,8 D
AF-Nikkor 18mmf/2,8 D
AF-Nikkor 20mm f/2.8 D
AF-Nikkor 24mm f/2.8 D
AF-Nikkor 28mm f/2,8 D
AF-Nikkor 35mm f/2 D
AF-Nikkor 85mm f/1.8 D
AF-Nikkor 85 mm f/1,4 D
AF-Nikkor DC 105mm f/2 D Defocus Control
AF-Nikkor DC 135mm/2 D Defocus Control
AF-Nikkor 180mm f/2,8 IF-ED D
AF-S Nikkor 200mm f/2 G IF-ED VR
AF-S Nikkor 300mm f/4 IF-ED
AF-S VR Nikkor 300mm f/2.8 G black
AF-S Nikkor 400mm f/2,8 ED VR black
AF-S Nikkor 500mm f/4 ED VR black
AF-S Nikkor 600mm f/4 ED VR black
AF-S DX Nikkor 12-24mm f/4 G
AF-S Nikkor 14-24mm f/2,8 G
AF-S Nikkor 17-35mm f/2,8 D
AF-S DX Nikkor 17-55mm f/2,8 IF-ED
AF-S VR Nikkor 70-300mm f/4,5-5.6 G IF ED
AF-Nikkor 18-35mm f/3,5-4,5 D
AF-S DX 18-55mm f/3,5-5,6G SILVER
AF-S DX 18-55mm f/3,5-5,6G BLACK
AF-S DX Nikkor 18-70mm f/3,5-4,5 G IF ED
AF-S DX Zoom 18-135mm F/3,5-5,6G IF-ED
AF-S DX VR II 18-200mm f/3,5-5,6G
AF-S Nikkor 24-70mm f/2,8G ED NEW
AF-Nikkor 24-85mm f/2,8-4,0 D
AF-S Nikkor 24-85mm f/3,5-4,5 G
AF-S VR Nikkor 24-120 f/3,5-5,6 black
AF-S Nikkor 28-70mm f/2,8 D
AF-Nikkor 28-105mm f/3.5-4.5 D
AF-Nikkor 28-200mm f/3.5-5,6D G silver
AF-S DX 55-200mm f/4-5,6G SILVER
AF-S DX 55-200mm f/4-5,6G BLACK
AF-S DX VR 55-200 / 5-5,6 G black
AF-Nikkor 35-70mm f/2.8 D
AF-Nikkor 80-200mm f/2.8 D
AF-S Nikkor 70-200mm f/2,8 G IF ED VR
AF-Nikkor 80-400mm f/4,5-5,6 D VR
AF-S VR Nikkor 200-400mm f/4G IF-ED
AF-Nikkor 16mm f/2,8 D
AF-Micro Nikkor 60mm f/2.8 D
PC-Micro-Nikkor 85mm f/2.8
AF-S VR Micro Nikkor 105mm f/2.8G IF-ED
AF-Micro Nikkor 200mm f/4 D IF-ED
Nikkor TC-14E II(moltiplicatore 1.4X per obiettivi AF-I/AF-S )
Nikkor TC-17E II(moltiplicatore 1.7X per obiettivi AF-I/AF-S )
Nikkor TC-20E II(moltiplicatore 2X per obiettivi AF-I/AF-S )
Che ne dite ????????? Che cos'altro posso acquistare ora ???????????
gianci
QUOTE(gbarbiera @ Jun 20 2008, 12:50 AM) *
eccoti il cuba leggero
le immagini devo risiedere già su un server per poterle rendere visibili.
quando scrivi il messaggio puo vedere delle icone in alto in una di queste c'è "inserisci immagine" e inserisci il link della foto
però ti manca il treppiedi e il bilico per portare in giro tutta l'attrezzatura smile.gif
alcarbo
Ottime idee Giancarlo... sentiamo gli altri
Per postare foto guarda qui
http://www.nikonclub.it/forum/index.php?sh...hl=postare+foto
Se non riesci rifatti sentire.
Per postarle visibili o hai un sito o usi lo spazio che ci lascia Nital
Io so usare solo il primo modo avendo un mini-sito www.alcarbo.info
le posto così fra apici [img]...http://www.alcarbo.info/foto.jpg ...
che chiuda con [/img] altri modi non li ricordo più
il bilico arriva arriva (nital eh)
Attilio PB
Volendo, cercherei anche un AF 28 f/1,4 ed un 58 f/1,2, già che ci sei... wink.gif
nippokid (was here)
...e poi cambierei il 12-24 f/4 con l'11-16 f/2.8 Tokina!!!
...come ho fatto io ph34r.gif ph34r.gif ...sssssssh...che è un segreto ph34r.gif
gianci
comunque è vero tra un po ci si menano pure....
gbarbiera
Grazie per il Cuba e per le spiegazioni.
Proverò e poi faccio sapere.
alcarbo
QUOTE(Attilio PB @ Jun 20 2008, 01:00 AM) *
Alfredo, ti manca il 24 PC
Mi vado a sparare una cicca
Ora vedo che manca anche il 16-85 vr e il 60 micro afs nuovo
QUOTE(nippokid @ Jun 20 2008, 01:01 AM) *
...come ho fatto io...sssssssh...che è un segreto
Eh si, lo leggono solo in 200.000 (però ora sono tutti a lavorare)
gianci
però ti manca anche questo....
alcarbo
Regalo uno dei miei obiettivi a scelta a chi lascia un post in questo 3d che sta languendo (o va stanotte o domani me lo chiudono)
http://www.nikonclub.it/forum/index.php?s=...t&p=1248361
QUOTE(gianci @ Jun 20 2008, 01:04 AM) *
provvedo
gbarbiera
Il parco ottiche di Alcarbo mi sembra OK a patto che abbia a disposizione almeno i seguenti corpi :
4 D40
4 D40X
4 D60
4 D80
4 D200
4 D300
4 D3
4 D50
4 D100
4 D70
16 D2 nei suoi vari modelli
in modo da montare su ognuno un ottica diversa senza dover perdere tempo a cambiarle a secondo della situazione. Per il trasporto suggerisco un piccolo leasing con Gondrad.
Nippokid ho visto che ti sei accattato l'11-16 della Tokina di cui avevamo parlato in altri 3d. Anch'io penso di prenderlo anche se è un DX, tanto anche se esce la D700 o che so altro a pieno formato la mia amata D200 non la mollo.
Attilio PB
Ragazzi, buona notte a tutti, mi tuffo nel letto, domattina ho ancora Giulia alle 9,30:
E poi ancora sabato pomeriggio..., se non finisce questo lavoro la faccio diventare radioattiva a forza di flashate laugh.gif
Attilio
gianci
QUOTE(gbarbiera @ Jun 20 2008, 01:13 AM) *
4 D40
4 D40X
4 D60
4 D80
4 D200
4 D300
4 D3
4 D50
4 D100
4 D70
non ho seguito molto l'altro 3d però ho visto che ne parlano molto bene del tokina.
io ho il sigma 10-20 che comunque mi soddisfa appieno
QUOTE(Attilio PB @ Jun 20 2008, 01:17 AM) *
Attilio
bello scatto attilio....
gbarbiera
Attilio non puoi postare a quest'ora le foto di Giulia.
Sono un'incitamento a non andare a letto. Li c'è la moglie bella, brava ma capisci a me ...........!!!!!
Spero non legga il post altrimenti mi ritrovo fuori di casa senza capire come è successo.
nippokid (was here)
...una DX l'avrò "per sempre", per alcune cose non potrei farne a meno, allo stato attuale della tecnologia...
Beh, mi limito a dire che su DX (attualmente) non ce n'è per nessuno!! Pensavo di usarla come lente "da battaglia", ma sono rimasto..diciamo..sorpreso...e così...
Consiglio di provarla, può non convincere perchè ha relativamente poca escursione...è quasi un fisso (per esagerare), ma ha la qualità di un fisso f/2.8 (per non esagerare)... wink.gif
Ah, su D3 può essere un 15-16 f/2.8!!
P.S. Attilio, vedo che vai forte col "lato B"... Pollice.gif ...buonanotte!!
gianci
QUOTE(gbarbiera @ Jun 20 2008, 01:29 AM) *
Giancarlo
ragazzi grazie come sempre per la piacevole compagnia....
ma è giunta l'ora di andare a nanna....ultima siga texano.gif e poi a letto
buona notte a tutti
ferdinanda
Mi piacerebbe intervenire per le difese delle mogli, specialmente quelle giovani e come dite voi brave e belle e.... capisco te ma in questi giorni non riesco a stare con voi a scherzare, mi è morto un parente a cui eravamo molto attaccati, be?! aveva 94 anni, ma anomalo per vitalità, guidava ancora, leggeva 4 giornali al giorno, viveva da solo, cucinando ecc insomma per noi già abbastanza vecchietti era un esempio che ancora avremmo potuto vivere qualche anno in attività e lucidità pertanto la scomparsa oltre all'affetto egoisticamente la interpretiamo come il girare dell'avvoltoio sulla testa.
Mi raccomando, non chiudete il bar, tra qualche giorno spero di essere di nuovo tra voi, in compagnia del consorte, che comincia a sentire la mancanza dell'acqua di misurina, infatti stanotte era in piena ipoglicemia con il diabete a 55.
Notte, e scusatemi per la nota stonata.
Tosca
nippokid (was here)
Buonanotte a te, Tosca....e un abbraccio.
Il bar resisterà e settimana prossima andrò a fare il pieno di Acqua di Misurina...in bici!! smile.gif
alcarbo
Di passaggio saluto tutti (fuori orario) e me ne vado. a presto
QUOTE(nippokid @ Jun 20 2008, 02:33 AM) *
E il blues non morirà mai (Zucchero a S. Siro l'altra sera). Grande..... ma questa è un'altra storia
alcarbo
Buon giorno a tutti voi. Appena alzato.
Lascio aperta la porta del bar e me ne vado a lavorare come l'altra notte
gbarbiera
Il sole sta tramontando e presto arriverà l'ora in cui il bar è aperto.
Prendo la chiave ed entro.
E' bello e ben fornito. C'è anche il pianoforte.
Speriamo che il pianista sia bravo e possa suonarci musica che rilassi e ci faccia perdere nei nostri pensieri più intimi.
Un caro saluto a Ferdinanda ed un abbraccio. Quella di ieri sulle mogli era una battuta stupidina.
Sono sposato da 33 anni, battibecchiamo spesso ma quando siamo lontani uno dall'altra ci prende un grande magone.
Non ho sentito pareri sulle mie due idee bislacche in particolare quella sulla Onlus per rimediare obbiettivi buoni aggratis. Possibile che questo non interessi a nesssuno oppure come Alfredo avete anche voi acquistato tutto il catalogo Nikon e quindi avete raggiunto la pace dei sensi.
Prendo una Coca liscia con ghiacchio accendo il mio Antico Toscano e trasportato dalla musica - Notturni di Chopin interpretati da Maurizio Pollini - inizio a perdermi dietro i miei pensieri.
Ci sentiamo nei prossimi giorni perchè causa impegni per domattina presto finiti la bibita ed il sigaro vado a dormire.
Ciao a tutti, felice notte.
Attilio PB
Buonasera a tutti, un saluto a Ferdinanda (magari non ti consola, ma il week end scorso ero in amabile conversazione con la nonna 97enne di un amico, lucida ed acuta, perfettamente autonoma al punto da vivere da sola, nonostante la frattura del femore oramai 6 anni fa...).
Io sono ricaduto nel tunnel "foto di Giulia", la mia signora oramai dorme, in sottofondo Paco de Lucia mi sta suonando il "Concierto De Aranjuez", il bicchiere di latte sta finendo...
Stamattina studio sugli scatti di domani, abbiamo poche ore e tante cose da fare, ci vuole che tutto funzioni bene...
Immaginate naturalmente la sommità di una torre medioevale, con alle spalle una verde vallata, al posto della mia poltrona una piccola piscina sopraelevata..., ci riuscite? Ammazza che fantasia tongue.gif
Cicca e torno...
Attilio
nippokid (was here)
QUOTE(alcarbo @ Jun 21 2008, 12:20 AM) *
Buon...giorno blink.gif a tutti.
Mentre alcarbo lavora ( hmmm.gif ), io mi faccio un drink!!
Un grazie a Giancarlo per il "mini-life" notturno...
...e un OK per la costituzione della O.N.L.U.S. (Obiettivi Non Limpidamente Utilizzati (dagli) Strùnz) biggrin.gif
bye.
....ciao Attilio... rolleyes.gif...io la "vallata" me la immagino... smile.gif
gianci
un rapido salto al bar per salutarvi e poi a letto biggrin.gif come nippokid anch'io prendo un drink e vado.
Ferdinanda so cosa vuol dire....avevo una nonna di 90anni che era fantastica, e la ricordo ancora con affettto.
giancarlo, adesso che è iniziato a fare bel tempo era ora di inaugurare la terrazza estiva al bar....per fortuna che ci hai pensato tu laugh.gif
invece vedo che attilio proseguirà il suo lavoro fino a fine estate...e forse anche oltre wink.gif
buona notte a tutti!!!!!
gianluca
Attilio PB
La ONLUS effettivamente mi sembra una buona idea, temo che comunque non risolviamo il problema..., io sono sorpreso che ancora non si parli di banding della d700 biggrin.gif , certo, questione di ore, già l'assenza di doppio strato di microlenti getterà nel panico tanti..., il 17-35 f/2,8 verrà nuovamente dichiarato inutilizzabile, il 14 f/2,8 da buttare, per non parlare del 70-200, se già va male sulla D3, figuriamoci senza doppie microlenti...
A volte mi chiedo chi diavolo osserva le foto di qualcuno, i miei committenti non hanno mai trovato nulla che non andasse negli scatti della D200, e non sono proprio tutti sprovveduti con l'anello al naso hmmm.gif , vabbè non pensiamoci...
Io domani porto il costume, con la scusa di qualche prospettiva "creativa" mi sa che mi faccio un bel bagno... rolleyes.gif , speriamo che i radiocomandi Skyport siano a tenuta d'acqua clorata...
Attilio
Attilio PB
QUOTE(gianci @ Jun 21 2008, 01:43 AM) *
Oddio, a dir la verità aspetto ancora una risposta ad un preventivo dove la modella è sempre Giulia...
Settimana prossima ho una modella nuova, mai fotografata, stai a vedere che finisco a fotografare fanciulle invece che estrusori ed imbottigliatrici... ph34r.gif
Attilio
Attilio PB
Allevi ha finito di suonare, io di studiare gli scatti, raggiungo la mogliettina nel letto.
Accosto la porta, qualcuno chiuda quando è ora.
Buonanotte.
Attilio
nippokid (was here)
uauuaaaaioau...chiudo và...lascio la chiave al solito posto...
'notte
zzzzzzzzzzzzzzzzzzzzzzzzzz
alcarbo
Di passaggio.....
Buon week end a tutti.
alcarbo
QUOTE(alcarbo @ Jun 21 2008, 05:41 AM) *
Di passaggio.....
Devo andare a "lavorare"
aria
QUOTE(alcarbo @ Jun 22 2008, 12:01 AM) *
Domani?
foen
notte, un bicchiere di latte e menta a tutti
aria
OK, al non risponde. Quello già dorme...
Buon lavoro e non fare casino quando ti alzi! Che c'è gente che ancora dorme a quelle ore! tongue.gif
nippokid (was here)
...povero alcarbo lavora sempre...
...Ooops, mancava la menta... IPB Immagine
gbarbiera
Bentrovati a tutti.
Scusate sono nuovo (del 3d) ma alcarbo che lavora sempre la notte fa la guardia Police.gif o il ladro ph34r.gif .
nippokid (was here)
ehm...secondo me fa il "collaudatore"...
gbarbiera
QUOTE(nippokid @ Jun 21 2008, 01:21 AM) *
bye.
Ciao Nippokid. Ottima l'interpretazione della sigla Onlus
aria
Mi astengo dal far battute perche ho letto la sua pagina personale che lavora in ambito legale ph34r.gif
Mi avete fatto venir voglia di un latte e menta ed ecco il risultato!
Una goduria
gbarbiera
Per chi volesse c'è anche la piscina
con il suo bar ristorante dove gustare ottime grigliate di pesce e fresche insalatone
e poi la notte al bar a sentire musica bevendo un Cuba Libre e fumando il solito Antico Toscano
tirando l'alba.
(Foto realizzate all'Isola d'Elba)
aria
No grazie il latte alla menta mi rende indigesta qualunque grigliata di mare...
Piuttosto donne c'e nè?
Perchè io adesso vado a nanna e almeno vi lascio in buona compagnia! biggrin.gif
nippokid (was here)
...donne? al sushi notturno? fiiiiii, pieno così...
aria
E' ora di tirarlo fuori questo forum notturno o è troppo presto?
E ma che diamine ieri me ne sono andato e non mi avete detto che arrivavano le conigliette. wub.gif
Attilio PB
A dir la verità io passo solo per un latte freddo al volo, stasera sono dilaniato, oggi avevo un paio di rimesse da sistemare e, tra le varie cose, mi sono spostato ben 32 damigiane blink.gif
Buon proseguimento nottambuli...
Attilio
ferdinanda
Per ben tre sere siamo passati a salutarvi poco prima delle cinque ma era impossibile connettersi.
abbiamo capito il perchè, quando ci siamo resi conto che a fine nottata avevate cose più importanti da fare (vedi conigliette) purtroppo attività inadatte a clienti del bar che frequentiamo di giorno
e dire che la foto l'abbiamo fatta negli anni '70
Tosca e marito
alcarbo
QUOTE(nippokid @ Jun 22 2008, 01:07 AM) *
http://www.jamdisco.com/eventi/prova3.jpg
belle le orecchie bianche
53 visitatori, 1 utenti pubblici, 0 utenti anonimi CAPITA DI RADO
alcarbo
Mostra dettagli per: Ultimo Click, Nome Utente
ferdinanda
Anche se è vietato,entro di giorno per una domanda tecnica, così non disturbo l'atmosfera scherzosa della notte.
Anche stanotte dopo le quattro mi si è sconnesso tutto il forum del club Nikon (solo quello), va bè pensavo ci saranno lavori in corso, ma adesso vedo che Alcarbo ha postato dopo le cinque, come è possibile che ciò accada solo aa alcuni utenti???
Grazie, Tosca
aria
Sbagliato! ieri sera e due sere fa era solo per uomini veri!
PS. chiedi ad un moderatore. Io non saprei come aiutarti.
Nessun problema noto al forum.
Spesso però non si riesce a connettersi per colpa dei provider internet., Specialmente quelli "non telecom", o dei guasti al DNS.
