NikonClub.it Community > PRODOTTI NIKON > NIKON PRODUCTS FAN CLUB > NIKON LENS fan club
Pagine: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432
Vincenzo I.
interessante
questo significa anche che a parità di focale e luminosità un obiettivo N è migliore di uno T?
oppure un 50 H f1,2 è meglio di un 50 S ma f1,4?
gciraso
QUOTE(Vincenzo I. @ Oct 29 2008, 11:53 AM) *
interessante
Non necessariamente: il numero delle lenti non individua un obbiettivo migliore di un altro, ma solo lo schema ottico impiegato (e neppure del tutto, dato che bisognerebbe indicare oltre che il numero anche i gruppi). E' una convenzione usata in passato da Nikon, quando ancora era Nippon Kogaku.
può servire anche a datare con buona approssimazione un obbiettivo.
Giovanni
salvari
Qualcuno conosce il 55/2.8 AIS MICRO NIKKOR, mi piacerebbe affiancarlo all D80.
g.snake
QUOTE(salvari @ Oct 29 2008, 12:36 PM) *
Ce l'aveva mio suocero e (spero ce l'abbia ancora) l'ha ereditato mio cognato...
Una stupenda ottica macro, estremamente inciso. Fa ottimamente il suo lavoro e lavora molto bene anche come "normale". La resa sull'analogico (mio suocero aveva una FM) era notevole. Sul digitale non saprei e dovresti attendere il parere di chi l'ha provato. Ma se tanto mi dà tanto... Almeno su Dx credo si faccia apprezzare (considerando anche che già sul 24x36 era 1:1). Considerando poi la relativa importanza dell'AF in macro è certamente da considerare una valida alternativa economica al 60 ed al 105 micro AF.
Giuseppe
ryo
Decisamente una delle migliori lenti mai prodotte dalla Nikon. Eccellente in macro e all’infinito. Praticamente esente da aberrazioni. Il miglior mix mai provato tra risoluzione e contrasto. Rapporto di ingrandimento massimo 1:2 (1:1 con l’anello dedicato). E’ il successore del mitico 55 f3,5 e ne onora meritatamente la fama. Una delle principali differenze con il predecessore è che è dotato di lenti flottanti e conseguentemente la sua lunghezza focale effettiva, in macro, si riduce.
Ottima la resa del colore e dello sfocato. Un vero gioiello dell’ottica. Oggi è acquistabile con poco, ma la sua quotazione è oscillante. Rispetto al suo successore (60 afd) ritengo sia superiore per uso generico all’infinito (in macro non si notano differenze di rilievo).
Marcello
PS: ne approfitto per aggiungere alla mia lista anche l’80-200 f4 ais
gciraso
Nuovo giunto 400 f3,5 Ai-S, non in buonissime condizioni, ma usabile. Appena ho pronto qualcosa, posto.
Giovanni
g.snake
QUOTE(ryo @ Oct 29 2008, 04:07 PM) *
....cut...
Marcello
Mi scuso per l'imprecisione sul RR del 55 micro. Effettivamente è 1:2, ma andavo a memoria.
Mi inchino poi alla precisione e completezza delle annotazioni di Marcello.
Giuseppe
g.snake
Approfitto per correggere la mia iscrizione:
Nikkor 50 mm f 1,4 modificato Ai
Nikkor Q 200 mm f 4 modificato Ai
Senza difficoltà particolari per il 50mm (ho trovato il giravite a stella adatto ed ho svitato le viti facilmente). Qualche difficoltà per il 200 mm, invece. Le viti sono con innesto a segmento sottile e largo. Difficile trovare il giravite adatto e comunque non davano segno di cedimento (tranne una). Piuttosto si rovinava l'attacco! Prima di rovinare le viti irrimediabilmente ho deciso di tentare di fare la modifica senza staccare la ghiera dei diaframmi... e ci sono riuscito. Ho usato un seghetto per il metallo! Ho protetto la lente posteriore, pulendo ripetutamente la polvere d'alluminio risultante. Ho procurato due tacche nei punti d'attacco della sezione da rimuovere e poi ho provveduto a segare la ghiera in senso tangenziale. Con un po' di pazienza ho potuto segare tutta la sezione da rimuovere approssimandomi alle due tacche agli estremi. Il pezzetto ad un certo punto è venuto via senza che avessi provocato danni alla flangia di metallo. Qualche rifinitura con la lima e via! Un bel lavoretto!
Appena ho qualcosa di decente con i suddetti la posto.
adibene
Qualcuno conosce questo signore ? Come potrebbe rendere su D700 ?
Alberto
E' il 20/2,8 AIS.
L'ho avuto e usato su F3.
Su D700 si comporterà certamente molto bene (AF a parte), poiché lo schema ottico è identico a quello del 20/2,8 AF (e AFD).
adibene
QUOTE(giannizadra @ Oct 30 2008, 06:34 PM) *
E' il 20/2,8 AIS.
Grazie Gianni,
ok per l'AF, abbastanza logico, ma cosa mi dici per quanto riguarda il controllo del diaframma ? Va usato rigorosamente in manuale, oppure gli AIS hanno l'accoppiamento meccanico controllabile dalla D700 ? E 175 caffe' (corretti grappa...) li puo' valere ?
TNX
Alberto
gciraso
QUOTE(adibene @ Oct 30 2008, 10:46 PM) *
Grazie Gianni,
TNX
Alberto
Controllo del diaframma rigidamente manuale. Sul prezzo non so.
Giovanni
Grazie Gianni,
TNX
Alberto
Piloterai il diaframma dalla ghiera dell'obiettivo.
Potrai quindi usare i modi A e M, conserverai l'uso dell'esposimetro (anche il Matrix), e se imposti a menù focale e luminosità massima avrai pure gli exif.
Questo perché (dalla D200 in su) le DSRL pro e semipro sono munite della levetta del simulatore di apertura e di accoppiamento AI.
gciraso
Finalmente oggi, complice un pallido solo dopo la Fulmine.gif sono riuscito a provare il 400 3,5 Ai-S. Sapevo che era buono e le prove mi hanno confortato. Tutte su D3. Exif nelle foto, purtroppo non è stato possibile abbassare gli ISO, cavalletto.
Provare la targa al 100%, please
Giovanni
Vincenzo I.
danardi
QUOTE(gciraso @ Nov 1 2008, 01:28 PM) *
Giovanni
Complimenti comunque, un bellissimo vetro
gciraso
QUOTE(danardi @ Nov 2 2008, 02:42 AM) *
Perchè pericoloso?
Giovanni
danardi
QUOTE(gciraso @ Nov 2 2008, 11:46 AM) *
Perchè pericoloso?
Giovanni
io non sarei flice di vedere un primo piano della mia targa online con tanto di auto, modello e colore.. gioco troppo facile per i clonatori di targhe
g.snake
Scherzo! Non credo davvero ci siano particolari problemi, non c'è la privacy per le auto e queste sono normalmente in strada alla vista di chiunque. Chi volesse clonare la targa di un auto se la fotograferebbe in proprio senza necessità di usare le foto di Giovanni. Al più l'unico "rischio" (se non è la sua) è che il proprietario noti le foto postate e non essendo d'accordo gli chieda "molto cortesemente" (visto che non credo ci siano limitazioni alla pubblicazione non per fini commerciali) di cancellarle.
Sulla lente: bella resa. Notevole il fatto che ad f11 resta superiore la resa anche a 1600Iso (ma qui conta la D3)... Oltre alla minore nitidezza a f3,5, domando a Giovanni quale delle 2 rende meglio ragione del colore dell'auto?
Giuseppe
gciraso
QUOTE(g.snake @ Nov 2 2008, 03:55 PM) *
Giuseppe
F11, ma devo nuovamente vedere a ISO decenti come si comporta. Già a 5,6 le differenze sono molto poco apprezzabili rispetto a f11. La giornata era molto buia.
Per la macchina, non è la mia, ma del mio vicino, che ha cortesemente acconsentito. Pure lui è appassionato.
Giovanni
g.snake
QUOTE(gciraso @ Nov 2 2008, 04:06 PM) *
Giovanni
ryo
Ciao Giovanni, vedo solo adesso le tue foto di prova del 400mm. Direi che il bestione si comporta molto bene. Ti rinnovo i miei complimenti per l'acquisto.
Marcello
gciraso
QUOTE(ryo @ Nov 3 2008, 09:18 AM) *
Marcello
Grazie Marcello, il problema del piccolo striscio della lente frontale pare sia risolto, non da problemi. Sono anche riuscito a trovare un TC-301 in eccellenti condizioni e pressochè inusato. Costo totale dell'operazione 550 euro.
Giovanni
Fabrizio31
del 18 Ais che mi dite?
QUOTE(Fabrizio31 @ Nov 3 2008, 11:36 AM) *
Rorslett ha segnalato grossi problemi di vignettatura anomala del 18 AIS su FX.
Unico caso patologico finora riscontrato.
Mauri.s
Anche a me pare migliore a diaframma chiuso, dove si nota pure un contrasto migliore.
Mi piace la resa del colore, molto reale e pulita..
le vecchie ottiche hanno una riproduzione della realtà, ormai dimenticata dry.gif
Ma 1/125 è con il cavalletto, vero ?
o sei un "drago" ?
Maurizio
gciraso
QUOTE(f5mau @ Nov 3 2008, 08:40 PM) *
o sei un "drago" ?
Maurizio
Giovanni
g.snake
QUOTE(gciraso @ Nov 3 2008, 09:02 PM) *
E vorrei vedere! Vista la tua occupazione secondaria (intendo dopo la fotografia tongue.gif ) c'è da augurarsi davvero che tu abbia una mano ben ferma! laugh.gif
Giuseppe
g.snake
Dovevo una foto d'iscrizione...
Niente di che... Situazione difficile: sera e luce artificiale dalla vetrina del negozio, niente cavalletto, 1600 Iso 1/50 f 4.
Ovviamente il 50mm f1,4 modificato (in casa) Ai.
IPB Immagine Ingrandimento full detail : 8.1 MB
Mi riprometto di fare di meglio anche con il 200mm
Giuseppe
lucnikon
QUOTE(lucnikon @ Sep 29 2008, 10:33 AM) *
Mi iscrivo, portando in dote:
- 55 micro Ai f2,8 + PK13;
- 300 f4 Ai.
In passato ho testato e 'tastato':
- 85 f2 Ai;
- 24 f2 Ai...
Sulla D200 andavano bene, posso solo immaginare ora sulla D300!!!
AGGIORNAMENTO AGGIORNAMENTO!!!
- 300 f4 Ai + ultimo arrivato:
- 105 f2,5 AiS trovato praticamente NUOVO con scatolo originale
Spero quanto prima di trovare il tempo di postare qualcosa...
gciraso
QUOTE(lucnikon @ Nov 4 2008, 10:16 AM) *
Ueilà, complimenti, facci vedere qualcosa!
Giovanni
iZack
Approfitto per chiedere una cosa: il 28/2 AIS rispetto al 28/2 AI ha subito cambiamenti allo schema ottico che ne hanno migliorato decisamente la resa?
Chiedo perché sulle pagine di Cavina in cui vengono confrontati alcuni 28 tra cui anche il 28/2 K (che se ho capito bene ha lo stesso schema ottico dell'AI), quest'ultimo verso i bordi non ne esce molto bene, anche molto diaframmato, rispetto agli altri fissi.
ryo
Ciao Zack, prova con questo link sempre ad uno degli articoli di Marco Cavina:
http://www.luciolepri.it/lc2/marcocavina/a...28mm/00_pag.htm
Spero di esserti stato di aiuto
Marcello
lucnikon
105 AiS ad f4... ottica molto bella!
foto
lucnikon
Aggiungo un 300mm Ai f4,5... non il modello ED.
Sicuramente denota tante 'pecche', ma per ora i miei 300mm passano solo per lui rolleyes.gif
IPB Immagine Ingrandimento full detail : 520.6 KB
Riaggungo anche il 105 f2,5 AiS, acquistato praticamente nuovo con scatola.
IPB Immagine Ingrandimento full detail : 51.4 KB
sergiobutta
Anche io ho delle novità acquistate nell'ultimo mese :
- un 43-86 pre AI in condizioni eccellenti, nel suo contenitore di cuoio originale. Uno spettacolo !
- " AI abbastanza usato ma funzionante pagato 39 euro; ho fatto qualche scatto, direi normale.
- un 300 Ai in buone condizioni. Ho fatto uno scatto ad una targa e mi sembra buono ...
I secondo 43-86 l'ho comprato per sostituire la ghiera posteriore e far diventare AI il primo. Ma ... le due ottiche sono sostanzialmente diverse, tanto per cominciare il primo è visibilmente più corto dell'altro.
- un 135 2,8 pagato 29 euro, in ottime condizioni meccaniche ma con le lenti piene di funghi.
Non ho ancora controllato se la ghiera posteriore può essere montato sul 43-86, ma voglio anche provare a far pulire la lente dal riparatore.
Le prove le farò quando avrò disponibili tutte le lenti e mi farò una bella passeggiata solo AI.
P.S. Credo che tutti voi conoscete il 43-86. Nella mia storia di nikonista pellicolaro l'avevo acquistato e venduto tre volte. Amavo le ottiche fisse, tutte più luminose. A vederlo oggi, si trova uno splendido oggetto, compatto, leggero, ben differente dai pesanti "guai" che siamo costretti a portare in borsa.
cuomonat
Un obiettivo per tutte le stagioni: AIS 35/1.4 su D700 a TA.
IPB Immagine Ingrandimento full detail : 409.4 KB
gciraso
QUOTE(cuomonat @ Nov 10 2008, 08:11 PM) *
Giovanni
danardi
35/1,4 AI su D3:
IPB Immagine Ingrandimento full detail : 147.4 KB
cuomonat
QUOTE(gciraso @ Nov 10 2008, 08:49 PM) *
Giovanni
Va bene anche un ritrattino? Sempre by AIS 35/1.4 TA:
IPB Immagine Ingrandimento full detail : 243.5 KB
enrico.cocco
Qualcuno ha nominato il 35/1.4 su D700?
Ecchime.
gciraso
Allora continuiamo: 35 1,4 su D3:
IPB Immagine Ingrandimento full detail : 322.6 KB
Giovanni
g.snake
Veramente una bella resa! A quanto si trova in giro?
Peccato, Natale, che tu non lo abbia inserito tra le ottiche senza cpu nel menu apposito. I dati exif non ne riportano i valori impostati.
@ Enrico.
La foto che hai linkato è fatta con il 28, IMHO
Giuseppe
Il 35/1,4 AI(s) si può trovare più o meno (dipende dallo stato d'uso) al prezzo di uno zoomino da kit acquistato fuori-kit.
Metto qualche altra immagine (prove fatte prima di prenderlo) su D3:
IPB Immagine Ingrandimento full detail : 260.1 KB
IPB Immagine Ingrandimento full detail : 1007.7 KB
IPB Immagine Ingrandimento full detail : 277.3 KB
IPB Immagine Ingrandimento full detail : 217.6 KB
enrico.cocco
Ciao Giuseppe,
la foto che ho fatto è fatta con il 35/1.4, se leggi i metadati c'è scritto 28 perchè temo di averlo usato senza aver aggiornato i dati obiettivo senza cpu sulla D700.
enrico
cuomonat
QUOTE(g.snake @ Nov 11 2008, 11:14 AM) *
@ Enrico.
Giuseppe
Bah...
Per la cronaca: è stata la prima uscita con la D700 ed avevo intenzione di usare il 17/35. L'amico che è uscito con me (mimmosena: testimone oculare che chiamo a deporre) voleva provarlo e così m'è venuta voglia di farci qualche scatto.
Risultato: il 17/35 me lo sono dimenticato.
mimmosena
QUOTE(cuomonat @ Nov 11 2008, 12:07 PM) *
Bah...
Mi dispiace deludervi ma eccovi la prova che vi ha preso tutti per i fondelli...
gli scatti postati da Natale sono tuttifatti con Canon 40D !!!!
cuomonat
QUOTE(mimmosena @ Nov 11 2008, 12:47 PM) *
Non era mia: lo dimostra il fatto che non indossavo la tracolla.
mimmosena
QUOTE(cuomonat @ Nov 11 2008, 12:51 PM) *
Naturalemnte scherzavo !! Era palese.... o no rolleyes.gif ? !!!
Posso confermare che sabato mattina abbiamo provato entrambi quello splendido
