NikonClub.it Community > PRODOTTI NIKON > NIKON PRODUCTS FAN CLUB > NIKON LENS fan club
Pagine: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432
zipzip
QUOTE(federico777 @ Apr 1 2012, 11:49 PM) *
F.
QUOTE(robermaga @ Apr 2 2012, 12:18 AM) *
Molto, molto bella la seconda. A questi rapporti e con soggetti in movimento il flash è (quasi) indispensabile.
Venendo al problema delle lenti, non conosco direttamente il 104 f4, ma conosco benissimo l'altro. Del f4 conosco la letteratura, perché per un po di tempo l'ho cercato pure io considerandolo una valida alternativa al più moderno 2,8. Hai colto bene i suoi vantaggi dovuti dovuti alle lenti non flottanti. Te ne suggerisco un'altro: ha una maggior distanza di lavoro, cosa utilissima e spesso sottovalutata in macro. Probabilmente non è performante come il 2,8 in un uso generico, ma per uno che possiede il favoloso (IL MAGICO wink.gif) 105 2,5, il problema non sussiste.
Quindi concordo con la scelta di tenere il 105 f4. E le foto sono molto belle.
P.s. Dimenticavo.... dai una soffiata al sensore. A diaframma chiuso le patacche si vedono ancor di più. laugh.gif
Grazie ragazzi. Roberto, hai visto anche che sfuocato da favola? E zero aberrazione cromatica. Non è che il 2,8 non sia un bellissimo obiettivo, ma la mia impressione è che col tempo la produzione Nikon, per poter tenere il passo col mercato abbia dovuto rinunciare a qualcosa dalla semplicità e della purezza originaria per ricorrere a sempre nuove diavolerie (tanto per citarne alcune: CRC, IF, AF, AFS, VR, nanetti vari…). Spesso i risultati si sono rivelati stupefacenti ma il prezzo è stato di aver perso un po’ di personalità in alcune realizzazioni. E forse è proprio questo sapore particolare che molti di noi cercano ancora negli obiettivi di una volta.
Anche per lo scatto col lampeggiatore ho usato il treppiede, comodo per lasciare la mano sinistra libera e usarla per impugnare il flash. Del resto io non sono Chuck Norris, che riuscirebbe a mettere a fuoco perfettamente un 200 mm a mano libera e ci manca solo l’oggetto volante colpito in pieno. biggrin.gif
QUOTE(rolubich @ Apr 2 2012, 02:09 AM) *
Mi sono sempre chiesto questa cosa, pensavo che fosse così ma non ne ero sicuro. Quindi, se la resa dell'obiettivo non viene pregiudicata, a 1:2 conviene usare il tubo se si utilizza il cavalletto, così il tutto è più equilibrato.
Attaccando il cavalletto al tubo, l'insieme con il mio corpo macchina D200 risulta abbastanza equilibrato. Però lo spazio tra la montatura e il corpo è molto ridotto e una testa a tre movimenti che ho interferisce con il battery grip se è montato e consente di scattare solo in verticale. Invece una testa a sfera midi Manfrotto 352rc si monta bene.
lilly1976
già postata
IPB Immagine Ingrandimento full detail : 680.3 KB
robermaga
QUOTE(zipzip @ Apr 2 2012, 11:17 PM) *
No, pure il 105 2,8 è un bellissimo obiettivo. Il blocco della maf è una perla e fra l'altro credo che sia uno dei pochi AIS ancora in produzione. Di sicuro è ancora in vendita nuovo (negli USA). Poi di sicuro quelle che chiami diavolerie a volte sono delle vere e proprie trovate commerciali, a volte (la maggior parte) sono utili evoluzioni, come il CRC o IF. Naturalmente ogni "miglioramento" comporta dei compromessi con le loro conseguenze. Quello che non reggo proprio nei moderni macro è la mancanza della ghiera dei diaframmi. Mi sembra una vera c.....a non poterli usare con PN11 o PK13 o soffietti.
E concordo sul PN11, non un semplice tubo, qualcosa di più wink.gif .
Come ti ho detto ho cercato un 105 f4, ma o mi capitavano dei rottami o volevano decisamente troppo. Poi io preferivo anche in questo caso l'AIS, quello con la carrozzeria uguale al 2,8..... prezzi da capogiro. Quindi capitandomi un AIS 200 f4 usatissimo, ma con lenti e movimenti buoni a prezzo stracciato, l'ho preso e mi sto allenando con quello. Fra l'altro possiedo il 60 AFD è l'accoppiata 60+200 mi sembra quasi migliore. Poi io ho un'età.... e mi devo solo divertire.
Non so se ti riferivi a me sull'uso a mano libera e sull'oggetto volante messicano.gif . Beh... quelle prove le ho fatte e pur buttandone più di mezze, come ho detto, qualcosa si può fare se non si hanno grandi pretese e su soggetti statici e ben illuminati. L'ape al volo non è un montaggio, e solo questione di scattare molto e avere c..o laugh.gif . In ogni caso concordo, il cavalletto è indispensabile, cosi come il flash. Tenendo presente che quando è buona (e sufficiente), la luce naturale è altra roba.
camcorna
QUOTE(lilly1976 @ Apr 2 2012, 09:30 PM) *
Oilà Giuseppe, veramente bella, sia il bianco e nero, sia il notturno.
Complimenti.
Ciao Camillo
camcorna
QUOTE(pietro58 @ Apr 2 2012, 07:55 PM) *
continuando, perché me devo sfoga..............
ancora " angeli "..................
Ingrandimento full detail : 839.7 KB
ed ancora " demoni"
Ingrandimento full detail : 975.8 KB
è duro il confronto e la scelta, certo che se le schede di memoria moderne sono cosi..........
Ingrandimento full detail : 858.6 KB
chissà quanti scatti si possono fare fino al " memory full" ?
correzione per la pagina precedente: il palco con il cane con le luci inquadrate è fatta col 18 f 3,5 e non con il 17 che era di un amico ma canonista rolleyes.gif
beh lo sfogo l'ho avuto, gli acquisti li ho fatti, 18-35-50,le vendite le metto in corso stasera 20,180,105 in forse
sono soddisfatto
un abbraccio
Pietro
Complimenti per lo sfogo Pietro, hai fatto un buon lavoro. Ma in paradiso distribuiscono troppo cioccolato e gli angeli poi hanno i brufoli sulla schiena.
Per il resto spero che non dimentichi questo club. Al di la delle sigle NPU ecc. e alla fissa per queste antiche meraviglie, è un bel club, e almeno si vedono delle foto. Ma fai bene a seguire la tua strada e ad avere il coraggio di cambiare. Mai fissarsi su qualcosa in cui non si crede, o seguire l'onda.
Scegli gli strumenti che preferisci e...... dimenticali....la vita sta altrove.....certe volte basta spostare il punto di ripresa della fotocamera e tutto cambia......può anche succedere che la pesantezza diventi leggerezza......
Camillo
pietro58
QUOTE(camcorna @ Apr 3 2012, 02:48 AM) *
Camillo
n'giorno a tutti,
molto profonde le tue parole Camillo e rispecchiano abbastanza il mio essere di "anima vagante"
no, non lo dimentico il club dove ho potuto attingere esperienze e competenze assimilando alcuni aspetti della fotografia, a me non congeniali, ed apprezzarli anche se con qualche polemica nel passato che ho mal digerito
è vero, mi ero stufato degli ai-ais ecc, ma come vedi tagliare del tutto i ponti col passato mi risulta difficile, allora cominciano le trasformazioni del corredo cercando di salvare capre e cavoli, lavoro e svago
ho messo in vendita il 20, il 105 ed anche il 180 che in fiera ha fatto gli straordinari, l'idea è che il 18 sostituisce il 20, il 35 mi ridà il normale su dx ed il 50 costava cosi poco e va cosi bene che era un peccato lasciarlo li da solo snobbato da tutti per la sola colpa di avere una E nel finale della sigla
sopra i 50 andrò di af, essendo il 180 la focale che uso di più e ci vedrei un 85 al posto del 105
contando sul fatto che vorrei abbinare alla D2, che userei per i tele, una D3 da usare al di sotto degli 85mm
come vedi cerco di mischiare rivoluzione ed evoluzione, chissà cosa ne esce fuori
intanto omaggio floreale per tutti
sempre 180 f2,8 ED su D2X 1/125 f2,8 iso 200
IPB Immagine Ingrandimento full detail : 926.7 KB
un abbraccio
Pietro
lilly1976
IPB Immagine Ingrandimento full detail : 858.1 KB
Dav_Bell_Photo
Sono riuscito a fare tre scatti tre al volo per provare un 135 ai-s che ho per le mani...chi , come voi, è nel mondo ai da lungo tempo ha sicuramente l'occhio "lungo" abbastanza per valutare lo stato della lente, vi chiedo quindi aiuto.
a ta
a 5.6
a ta
senza ritocco solo conversione jpg con viewnx.
Grazie per l'aiuto.
pietro58
QUOTE(lilly1976 @ Apr 3 2012, 12:34 PM) *
bella questa Giuseppe,
ma non mi tentare, allargare di altri 2 mm proprio io che ero allergico sotto i 50 mmm...............
un abbraccio
Pietro
macromicro
certamente delle belle foto; alla fine è il 'manico' ,come si suol dire, che conta
pietro58
[/quote]
pietro
tix88
QUOTE(lilly1976 @ Apr 2 2012, 11:46 PM) *
lilly1976
QUOTE(tix88 @ Apr 3 2012, 01:43 PM) *
Pollice.gif sono innamorato di Siracusa.Ciao
pietro58
ombre
180 2,8 ED su D2X 1/125 f 4
IPB Immagine Ingrandimento full detail : 973.3 KB
Pietro
robermaga
QUOTE(e.david @ Apr 3 2012, 12:40 PM) *
a ta
a 5.6
a ta
Grazie per l'aiuto.
A me sembra ottimo, ma è un'ottica che non ho. Ci vorrebbe Gian Carlo che ne è un grande estimatore.
Magari ci dicessi che tipo è, 3,5 o 2,8 e magari su che fotocamera l'hai montato.....
lorenzoc.
urca quanto avete scritto, complimenti a tutti per le belle immagini, alcune stupende!
@ Pietro58 eri li sabato pomeriggio? il cane l'ho visto anch'io!
pietro58
QUOTE(Whitecossie @ Apr 3 2012, 04:01 PM) *
si White, hanno dovuto sbattermi fuori a forza in cinque per mollare l'accoppiata D4-600 f4 e convincermi a riprendere la mia D2X e 180 ED wink.gif
visto il gadget? caruccia la borsa per uscite leggere, non mi aspettavo tanto
Pietro
lorenzoc.
QUOTE(pietro58 @ Apr 3 2012, 04:08 PM) *
Pietro
non mi ero registrato non sapendo quando andavo, certo che se sapevo che regalavano la borsa avrei chiesto ugualmente, peccato..
comunque quanta gente in fiera, in certi punti non si camminava rolleyes.gif
pietro58
in effetti, specie nell'usato c'era un mare di gente
allo stand Nital, uguale sia per le modelle che per le macchine nuove, fortuna erano tutti a provare le 800 cosi mi sono goduto una D4 per più di 10 min in santa pace ed ho potuto valutare di persona se mi debbo inguaiare per benino o no tongue.gif
intanto che aspetto il superenalotto
Nikkor 180 f2,8 ED su D2X 1/80 f2,8 iso 400
IPB Immagine Ingrandimento full detail : 875.9 KB
Pietro
lorenzoc.
QUOTE(pietro58 @ Apr 3 2012, 04:50 PM) *
Pietro
robermaga
Continuo l'allenamento... micro 200 AIS
....questa volta con cavalletto tongue.gif .
questa a f16
IPB Immagine Ingrandimento full detail : 430.4 KB
e questa a f5,6
IPB Immagine Ingrandimento full detail : 333.6 KB
..raga, i passaggi del colore mi sembrano notevoli biggrin.gif .
macromicro
QUOTE(pietro58 @ Apr 3 2012, 01:10 PM) *
pietro
A qualche mercatino, i ...cinesi imitano e producono di tutto laugh.gif Pollice.gif
lorenzoc.
QUOTE(robermaga @ Apr 3 2012, 05:32 PM) *
questa a f16
e questa a f5,6
veramente gradevoli, colori stupendi, per me la seconda Pollice.gif anche se non sono riuscito ad aprirla probabilmente causa rallentamenti del sito..
division e-foto
il simpaticone del borgo S.Maria...con AIS 28mm f 3,5. CIAO!
Untitled di division e-foto, su Flickr
Dav_Bell_Photo
QUOTE(robermaga @ Apr 3 2012, 03:59 PM) *
Si scusa mi ero di dimenticato che di 135 Ai-S c'è anche l' F/2; è la versione F/2.8 N° 956xxx ( e poi non mi ricordo) quindi è un 2003 o 2004 direi. Aspettiamo Gian Carlo che la sue prove da Catselletto le avrà sicuramente fatte wink.gif
Freeway
QUOTE("e.david")
è la versione F/2.8
dai tuoi post lo trovo eccellente gia' a TA.. , piccolo e compatto e' un buon tele, anche se considero
il raro F2 una spanna sopra.. specialmente nello sfocato. de gustibus.
ciao !
lilly1976
a ta
a 5.6
a ta
Grazie per l'aiuto.
lilly1976
a ta
a 5.6
a ta
Grazie per l'aiuto.
mk1
QUOTE(e.david @ Apr 3 2012, 06:46 PM) *
Beh, se per questo, oltre alla versione f 2, c'è la 2,8 ma non dimentichiamo la 3,5.
A mio avviso sono tutte ottime, dipende da quello che si vuole ottenere, dal peso che si è disposti a portarsi dietro e da quanto si può spendere.
Certo che la versione f 2 è più prestigiosa ed è molto valida a TA con uno sfocato irrangiungibile dalle altre versioni, però a diaframmi più chiusi mi sembra che i meno luminosi siano pari se non meglio. Il peso e l'ingombro del 135/2 poi, sono notevoli.
Le immagini del 135/2 mi sembrano molto nitide, con un ottimo sfocato ma con una " presenza" generale leggermente sbiadita, come se mancassero di contrasto e saturazione.
Sono sensazioni perchè, pur avendoli, non li ho mai confrontati direttamente.
La tua ottica mi sembra a posto. Tuttavia per essere sicuri del perfetto stato delle lenti bisognerebbe fare delle riprese ad ok che si fanno normalmente per verificare ottiche un pò maltrattate o manomesse. Se esteticamente e meccanicamente è in buone condizioni, direi che puoi andare tranquillo.
Filippo.
lilly1976
QUOTE(pietro58 @ Apr 3 2012, 12:41 PM) *
un abbraccio
Pietro
Grazie Pietro, con il passare degli anni le focali lunghe sono difficili a gestire ,tu sei un grande non solo a gestire il 180mm. continuo a tentarti.....Ciao
IPB Immagine Ingrandimento full detail : 817.4 KBIPB Immagine Ingrandimento full detail : 970.8 KB
Gian Carlo F
a ta
a 5.6
a ta
Grazie per l'aiuto.
belle!
questa a f16
e questa a f5,6
belle!
Anche io ho un AIS f2,8 e che dire..., secondo me, è un grandissimo obiettivo.
Leggero, compatto, molto performante e si trova in giro a cifre molto abbordabili, cosa vogliamo di più? smile.gif
Una altra performace notevole la da anche in macro, essendo un'ottica nitida e ben contrastata e che chiude a f32; ricordo di aver ottenuto immagini addirittura più nitide del 105mm f2,8 AIS Micro, ovviamente è più scomodo da usare in quanto occorrono tubi o soffietto, ma la sua resa è spettacolare.
lilly1976
IPB Immagine Ingrandimento full detail : 943.9 KB
Dav_Bell_Photo
Ringrazio Filippo e Gian Carlo per i preziosi consigli e per le loro opinioni. Penso di riuscire a strappare un buon prezzo per questa lente, speriamo...intanto finché mi rimane "in prova" cercherò di scattare e scattare wink.gif
S_M_Art
Credevate di esservi liberati di me?!?
D700 + AI-S 300 / 4,5 IF ED (1250 iso, 1/250, f5,6), crop.
IPB Immagine Ingrandimento full detail : 1.4 MB
marcgast92
--- di Guasta_, su Flickr
lilly1976
QUOTE(Marco.Guasta @ Apr 4 2012, 12:14 PM) *
Dria
Ottime,la prima su tutte... complimenti!
division e-foto
Belle!! Personalmente, forse, non avrei ruotato la seconda (credo lo sia)...
Le vedo gia' stampate min.20x30 su carta rigorosamente opaca e magari ruvida.
Ho fatto tutto da me...ma ovviamente e' la mia interpretazione.
http://www.flickr.com/photos/division-e-foto/
Piccolissimo saluto OffTopic
@ federico777 :grazie per la visita...CIAO!
federico777
QUOTE(lilly1976 @ Apr 3 2012, 09:29 PM) *
Belle... piazza Università e via Crociferi a Catania, eh? Della piazza ne ho una simile proprio adesso su Flickr, ma non ne sono soddisfatto al 100% (cielo schifoso, come al solito quando esco a far foto) smile.gif
F.
lilly1976
QUOTE(federico777 @ Apr 4 2012, 04:06 PM) *
F.
grazie Federico,mandami il link sono curioso di vederla..
federico777
QUOTE(lilly1976 @ Apr 4 2012, 05:19 PM) *
http://www.flickr.com/photos/federico777/6.../in/photostream
Federico
Gian Carlo F
QUOTE(lilly1976 @ Apr 3 2012, 10:18 PM) *
QUOTE(S_M_Art @ Apr 4 2012, 12:07 AM) *
Ragazzi ! Complimenti a tutti! State postando immagini davvero notevoli!
Che dire...
Bentornato S.M.Art!
Marco i tuoi ritratti sono proprio belli, la mia preferenza va alla seconda immagine.
federico777
20 f/2.8 AIS, interno del S.Pietro a Modica, 1600/3200 asa.
IPB Immagine Ingrandimento full detail : 2.1 MB
IPB Immagine Ingrandimento full detail : 1.9 MB
IPB Immagine Ingrandimento full detail : 2 MB
Federico
mauropanichi
Molto belli i ritratti e conversione di Marco,splendido il 50 1,2
Vado con un ritratto con il pur splendido 105 1,8 ais con D3 a soli 5000 iso
IPB Immagine Ingrandimento full detail : 634.4 KB
S_M_Art
Troppo facile fotografar modelle che se ne stanno ferme ferme...
E' come andare a caccia dentro lo zoo!
(dico così solo perché le foto sono splendide... e io sono invidioso, tipo "volpe e l'uva", ...e le modelle non ce le ho)
Sono davvero contento. Ho scoperto una cosa che sicuramente sapete tutti ma che, io che sono tonto, non sapevo.
Finora avevo sempre scattato col "bilanciamento del bianco" in "auto".
E, con luce artificiale e alti iso, era 'na schifezza: dominanti gialle difficilissime da smorzare anche in PP.
Ora sto scattando sempre con "luce solare", anche la notte, anche al buio, e tutto è tornato a posto!
Grazie, Giancarlo, per il "bentornato"!
Buone foto a tutt*!
Me ne torno in apnea (troppe cose da fare, troppe cose da fare, troppe cose da fare, ...): ci "rivediamo" tra sei mesi...
mk1
IPB Immagine Ingrandimento full detail : 757.6 KB
Lo so, è sfruttamento di minore, ma giuro che si è offerto spontaneamente.
D200 e 85/1,8 Nikkor-H
macromicro
QUOTE(mk1 @ Apr 5 2012, 12:23 AM) *
Ha meritato, almeno, un dolcetto/caramella?
Gian Carlo F
QUOTE(federico777 @ Apr 4 2012, 07:57 PM) *
belle Federico!
Modica è stupenda, ho ricordi bellissimi di quella zona della Scilia: Modica, Ragusa, Scicli, Noto....
QUOTE(S_M_Art @ Apr 4 2012, 11:06 PM) *
Buone foto a tutt*!
Ma sai che non ci avevo mai pensato.... tanto se si scatta in RAW poi la temperatura colore si può modificare in PP a piacere.
A proposito, ho visto che sono in vendita dei tappi obiettivo con la parte centrale bianco opale (cineserie) proprio per meglio determinare il bilanciamento del bianco.
Bella Filippo, l'85mm mi piace da matti, ha un timbro bellissimo (tipo 180mm)
QUOTE(Batman62 @ Apr 4 2012, 08:19 PM) *
fabio1961
Vi leggo ... ma da poco tecnico non intervengo... uno scattino con il mio 20mm 2.8 ais
IPB Immagine Ingrandimento full detail : 249.5 KB
camcorna
